:iagree:Both waterless and rinseless washes use polymers to lift and encapsulate dirt from the paint surface so they can be picked up by MFs. I only do waterless if the car is lightly dirty. The key is not to scrub the dirt into the paint. I use lots of long nap MFs and little pressure.
even when i properly used a cal duster on VERY light dust.
budinsc
. no matter what techniques i used in washing it happened even when i properly used a cal duster on VERY light dust.
budinsc
How can a waterless car wash not introduce micro marring if the car has any dirt whatsoever? Is this to be used only on dusty cars? I seem to have a hard time not getting micro marring even with 2 bucket etc. etc.
Micro-Marring, doesn't that imply that its too small to be seen. How in fact did you actually notice this "mirco-marring"? What I find even more interesting is that
a cal duster with very light dust can mare/scratch car paint and the clear coat.
I dont know the hardness factor of dust, cal dusters etc as compared to car paint but I sure wish a paint chemist was part of the forum. He sure could offer allot in regards to this and other topics. Myth and Fact are so frequently blurred
Paint/clear-coat paint hardness is often gauged/referred to where it fits in the Mohs and/or Pencil Hardness tests. Some examples:
Some tests OEM's require from paint manufacturers (Bolded tests may relate somewhat to your inquiry)
-4000 hour weatherometer
-ASTM D3363 pencil hardness
-Amtec Kistler - Car Wash Test
-Crockmeter test
-Tukon hardness
-ASTM D524 gloss (20¡/60¡)
-ASTM D3359 adhesion test method B
-ASTM D4060 abrasion resistance
-ASTM D4752 MEK resistance
-ASTM D1308 chemical spot resistance
-ASTM D1308 skydrol immersion (7 days)
-ASTM D522 flexibility test
-ASTM D2794 impact resistance direct
- ASTM B117 salt spray test method
-Water contact degree angle
-ASTM D4585 humidity resistance
-ASTM D3170 chip resistance
-ASTM D968 falling sand abrasion (100 liters)
____________________________________________________
Pencil Hardness of paints/coatings (Hard to find out which paints and by what paint manufacturers OEM's utilize at any given moment)
Catalyzed polyester: 9H
Catalyzed polyurethane: 9H
Catalyzed Modified Acrylic polyurethane: 4H ***
Catalyzed Acrylic polyurethane: 2H ***
Water-based polyurethane: 3H ***
Water-based urethane/Isocyanate Catalyst: 2H ***
Conversion varnish: 4H
Low VOC Catalyzed laquer (24 hrs): 2H
Low VOC laquer: 3H
Urethane/Nitrocellulose laquer (24 hrs): F
Water reducible laquer: 2H
Tung oil/polyurethane wipe-on finish: 2H
Water-based polyurethane wipe-on finish: HB-F
Aerosol precat: 3B
Aerosol water clear acrylic: 3B
Aerosol clear shellac: 3B
Aerosol nitrocellulose/polyurethane: HB
Aerosol nitrocellulose: 3B
Amber (orange) Shellac: 3B
Pencil Hardness Scale:
9H 8H 7H 6H 5H 4H 3H 2H H
Hardest -> -> ->
F HB
Medium -> ->
B 2B 3B 4B 5B 6B 7B 8B 9B
-> -> -> Softest
Moh's Scale:
(IMO...May apply to hardness of paint/clear-coat paint? Why is hardness of various minerals important? Abrasives are manufactured from minerals and are in compounds/polishes.)
Mineral Hardness
Diamond 10
Corundum 9
Topaz 8
Quartz 7
Orthoclase 6
Apatite 5
Fluorite 4
Calcite 3
Gypsum 2
Talc 1
-Sorry to report that most clear-coat paint films are nowhere near the very top portion on either the Pencil Hardness or Moh's Scales test. But are they getting "better"..perhaps...but still getting thinner...that's a fact!
-Haven't been able, as of yet, to locate the Original California Duster's fibers actual placement on either of the above Scales. Need the OCalDuster's fibers make-up information, in order to possibly determine its abilities to inflict micro-marring on a given clear-coat paint. Will post that info, when obtained, ASAP.
-And...It would be very difficult to place where "dust" fits on these Scales, without having a sample of the particular "dust" that lies atop the vehicles in question to take to the Lab....To possibly determine its impact, if any, on a given clear-coat paint as well. Too many, and different levels, of "dustiness".
-I agree with your premise/definition of micro-marring to a point. But this Mike Phillips article, IMO, is more meaningful:
http://www.autogeekonline.net/forum...uffer-swirls-cobweb-swirls-micro-marring.html
Moh's and Pencil Hardness Updates (as promised) of:
In conclusion:
Using The Original California Duster, with its "special paraffin waxed" cotton strands (RE: Stiffened, waxed, petroleum aroma, to an unknown degree...see above)....On vehicles' "dusty" (quartz embedded) top-coat paint film surfaces does, IMHO, have quite the ability to inflict micro-marring to: Softer-than-quartz top-coat paint surfaces....no matter the dusting techniques one employs. I, for one, will not take that risk.
Note: Please feel free to call these micro-marring "blemishes" by other well-known 'detailing nomenclatures', if you so desire.
Interesting stuff, well done. I think the only thing missing are the downward forces required to inflict these blemishes.
Thanks again for the details!!
