Stephan@FamouslyHot
- Mar 13, 2014
- 71
Hey gang
Was trying out the waterless wash method again and can't say that I am sold on it yet.
I was using the Pinnacle wash with wax, with a regular spray nozzle from Autogeek, with the blue and grey dual sided waterless wash microfibers.
The technique I was using was spraying down the panel, and then using the swipe technique , I believe from Mr. Stoops, where after each swipe, you adjust the towel slightly to a clean portion. After each swipe, I did not need to use a different towel to 'dry' the section, as the towel absorbed the liquid and dirt.
Maybe my car had a bit too much dirt on it, but it worked fairly well. Only problem I was running into was the overspray from working on another section would leave small spritz of dried product onto areas I just cleaned.
I used D114 @ 1/128 for the windows but used a spray bottle with the Kwazaar sprayer, and wow that sprayer rocks compared to the white sprayer.
I think the concern that I have is, I have a world rally blue Subaru, and gosh, that paint is so soft it gets slight scratches just looking at it. So the waterless wash makes me a smidge nervous to use, I have had great luck with keeping scratches to a minimum with the 2 bucket rinseless method, and best results with a hose.
Does anyone have any tips on how to control overspray spots?
How do you clean very dirty areas like mud flaps or wheels/bumpers? Just spray the heck out of it?
How much spray is actually needed? Enough to soak the section that you are working on?
After doing a waterless for two or three washes, the 32oz. sprayer is almost empty. Does anyone have any tips or what do you all use to keep a larger mixed batch, so that when you run out in the sprayer, it's a quick re fill, instead of busting out the measuring cups again so frequently?
Thank you
Stephan
Thank you
Stephan
