Has anyone experimented with removing wax or any protection from using a foam cannon? Anything you can throw in with say a dedicated foaming soap that will assist in stripping any current protection?
Adding solvents such as PrepSol, or P21S TAW to a foam cannon's dedicated foaming soap--along with a wash mitt (for agitation)---will assist in removing many protection-products.Has anyone experimented with removing wax or any protection from using a foam cannon? Anything you can throw in with say a dedicated foaming soap that will assist in stripping any current protection?
IME it doesn't work. It's hard enough to remove a decent LSP with LSP stripping designed products and agitation - no touch LSP removal is like no touch car washes: a pipe dream at this time.
Wheel Bright may do it.
Thanks guys. Starting some dealership work and looking to combine some steps if possible. On the ...... Killing two birds with one stone front, are there any truly good wash n wax combos out there. Specifically that can be sent through a foam cannon
What ratio do you use?
Well wash n waxes aren't actually using wax. They use a synthetic gloss enhancifier. For dealership cars, they don't give two poops about polishing and high quality products. They want something that looks good, fast and CHEAP. For this reason I feel CG extreme wash n wax would be best. It can be used in a cannon no issue and it is packed full of gloss enhancers. It's a really fast way to make something look good.
I've tried a lot of different products at chemically stripping LSPs to no avail at various ratios. Even with agitation it's hit or miss with a quality polymer sealant - mostly miss.
Does anyone know what will strip a wax, sealant or coating? I know they are not the same and different products may be needed even at each level depending on the brand used (wax, sealant or coating).
Dawn is commonly mentioned to strip wax, but I have seen it proved wrong that it may add a coating that makes water act differently on the surface than a wax, sealant or coating to make it seem like it stripped the protection but really did not.
What would IPA strip and in what percentage? Degreaser? Paint thinner? Not that I would use any of these on the whole car. What would you do if you wanted to strip the protection on a section or panel without removing paint with polish or is there such a thing?
