WD40 Uses...
lunchboxmunchy
Hey Geeks. What kinda uses has everyone heard of for WD40? Specifically for auto detailing. I know of a quite a few random uses. My neighbor says that he uses it for dressing the plastic pieces in the engine compartment and the wheel wells. IMO, that's pretty clever. However, I dunno how "safe" that is.
Feed back please
Specifically for auto detailing? Other than as a solvent to remove caked on tar, nothing. From my experience with it, it's sticky and attracts dirt and dust.
It contains non-volatile oils which are specifically intended to persist on surfaces so as to provide lubrication. As you say, it thus is sticky and attracts dirt. People do use it as a solvent but this is a very poor use of the product because it is designed to be hard to remove and water repellent. If you want to get rid of tar or heavy grime, WD40 is the wrong product - use a proper tar remover or solvent degreaser. This will rinse off much more easily to leave no residues.
I'm not the one who uses WD40 for auto detailing and i agree with your statement that it's the wrong product. That's the most relevant thing i could think of for WD40 in auto detailing. As a matter of fact i use it regularly for my road bicycle to clean the chain, derailer, cassette, and any random grease. But in my opinion it does not belong in an auto detailers arsenal.
WD40 is completelly safe. It's fish oil. It has probably a 1000 uses, Google it.
As for auto detailing, it could be used for a few things;
- removing stickers
- preventing fog on Windows
- cleaning different things
- lubricant
probably a lot more. But there are certainly products that will do a better job at each task you could use WD40 for. I have a can of it in my detailing kit but I have not used it yet. I keep it just in case I come upon something I don't know how to fix, there is a chance if I Google the problem that WD40 will be the solution ;)
WD40 is kinda like Duct Tape, your better off having some around than not.
One thing I read online, so it must be true ... hehehe.... is that it can be used to remove corrosion off aluminum rims. I will let you know how true that is in about 2 weeks. lol
Sent from my DROID3 using Tapatalk 2
Have a buddy that sprays his knees and elbows with it before he starts working in the morning. Swears it loosens the joints. I think it's hilarious and quite funny to witness. But I guess if you're a detailer with squeaky knees and elbows then WD-40 has a place in your arsenal!
I just tried that, no joy! Just spritzed some on a shop rag, nothing happened.
I WILL give it better go later, to allow it to dwell more.
Bill
Maybe it would help remove the corrosion salts (although I have never heard that or tried it), but it's not going to do anything about the pitting.
I like mine on toast in the morning, way less cholesterol than butter (well, it doesn't say anything about cholesterol on the can...)
Someone (perhaps you) tried to tell me this before. I am sorry but it is nonsense. Check out this from the makers - myth I am afraid. Still don't believe it, check out the MSDS. Section 3 shows the ingredients - aliphatic hydrocarbon, petroleum base oil and LVP aliphatic hydrocarbon make up about 90% of the product. These are all derived from petroleum distillation - nothing to do with fish!
Nothing dangerous, specifically, but what I stated above is correct. It contains lubricating oils which are non-volatile. They do not evaporate away. They stick, they persist and that is part of the reason they work as lubricants (and a large part of the reason why gasoline is useless for long term lubricating - it DOES evaporate so can't lubricate after it is gone). WD40 is designed to leave this residue and it is designed to be water resistant. Yeah, it will remove tar/glue etc. because it has all those hydrocarbon solvents but it will also leave behind that residue. That needs really thoroughly washed off. As a quick job, that might be fine but anyone who is justified calling themselves a detailer should be using a solvent based degreaser which contains emulsifiers such that it will need only a rinse, not a thorough wash. In actual practice, you would be better using mineral spirits than this, at least mineral spirits will evaporate away if you leave it long enough.
For reference, my company formulates, manufactures and sells chemical products.
I think it was Rustoleum that once upon a time had fish oil in it, or fish heads, or oil from fish heads...
My favorite WD-40 usage is on stubborn fasteners I sometimes encounter when roaming the dairy aisle.
Along with a few other 'ointments'...It has becomes a mainstay in the nightstand.
Im the MAN
That's what I was trying it on. Wife's car just got new tires last week and where the wheel weights were...:doh: SALT leftovers! I've been a bit behind on the to-do list (actually it's the Honey-Do list) to get after it (shame on me).
Bill
Coated weights man! Or better yet do stick-on on the barrel. I just found out that the EPA is trying to voluntarily ban lead weights, so now I have plated iron ones (?)...I'm sure they will look very nice once they rust thru the plating.
That's surprising because in all the videos and texts I have seen about WD40 it always mentions it is perfectly safe. I am too lazy to do a search right now, but I will later.
I have it in the house, but WD40 is banned from my garage and I would never use it on any of my vehicles. Auto painters worst nightmare is someone spraying this fisheye in a can 100ft away from a vehicle. It's the wrong product for squeaky car door/hood hinge's etc. White lithium grease is the proper product used for these types of squeaks. If you like using WD on your car... knock yourself out and fisheye on brother :xyxthumbs:
Haha. Let me reiterate that I don't use this product while detailing vehicles. I'll use it for other uses that it is intended for. I was just curious.
Im the MAN
I was 11-13 (kid basically)
I shot the engine with the a degreaser (don't know the name but it is OTC, white spray can)
Well... After cleaning the engine, I sprayed WD-40 lol :D
Then, when the car was ready for delivery, they turned it on and let it "fume out"
Again, I was a kid and was to young to drive :D
I said it is unsuitable for paintwork. Another poster has pointed out the results it can give in one setting -fisheye defects. It is quite safe, just not something that fits in the bag of a detailer.
Bill
Follow up...I used a chunk of a cotton ball saturated with WD, tape it to the tire/wheel and just let it sit for maybe 2 hours.
Results? Nothing. The salt crystals (or whatever the correct name is) just laughed at it.
Oh well, we tried.
Bill
