Fast On/Fast Off ?Waxmax said:I do the entire car and then wipe it off (FOFO).
Mr. Clean said:I'm not familiar with the Prime Strong product. Has it replaced Prime or is an addition to the line?
I've read where Prime is compared to KAIO. I'm most interested in the cleaning component, but overall comparisons are welcome.
Carnauba Jett is a SOWO product....one section at a time ( typical car hood would be four sections)....what method did you use? This is the product that we use on mobile detail of bikes as a LSP. It is always in sunlight and heat(spring and summer) It has never attempted to dry using SOWO.killrwheels@autogeek said:I have found the line slightly finicky like Klasse SG. And it does not like sunlight nor heat. I actually had to rewash the car to remove the Carnuaba product and have moved it to the back of the shelve.
The acrylic products are nice and glad someone else besides Sonus now offers an Acrylic based QD'er. (Menzernas streaks to darn much) I wonder how much easier Trigger is to use versus the Acrylic Sealant since mine came with a spray nozzle and worked very well that way.
3Dog said:Carnauba Jett is a SOWO product....one section at a time ( typical car hood would be four sections)....what method did you use? This is the product that we use on mobile detail of bikes as a LSP. It is always in sunlight and heat(spring and summer) It has never attempted to dry using SOWO.
maesal said:Could you compare AJ vs AJT? I'm a big AJT fan, but I think AJ will last and protect more than AJT, because otherwise Jeff will only sell AJT. I was thinking about putting the first or 2 first coats of AJ and after it use AJT to put more coats. What do you think about that?
Does anybody know if AJ and AJT have nanotechnology? And... AJ and Carlack68 Nano are the same product?
Thanks !!
killrwheels@autogeek said:first nanotechnology is basically marketing hype ... just like the ole Teflon in wax and such. Nobody to date has provided concrete proof that any protection works better than another. So tread lightly ...
As for AJ, it comes with a spray top also. Thats the only way I used it. Still finicky like Klasse SG but better gloss. I dont know if Trigger is lightened in anyway like a Spray Sealant versus liquid sealant, but using anything on a routine basis is likely to give the same results and protection.
maesal said:Thanks for the comments. I used Klasse SG and I liked. Then used AJT and amazed. I'm liking acrylic after years of carnauba fan. I didn't notice that AJ comes with spray.
Thanks killr.
JeffW said:I'm also a big fan of acrylic spray-QDs over carnauba on my daily driver... thus far I've used Menzerna's HGAS and AJT, and to be honest I much prefer HGAS. HGAS, for me, is easier to apply and has not streaked at all, whereas AJT seems thicker and streaks like mad no matter how light I put it on.
Edited: I have found that after applying AJT and it streaking going over it again with Jeffs Acrylic Glos helps a ton in reducing the streaking and boosting the gloss. Maybe I am just applying too much AJT. Hmmm...
Regardless, the look I get with acrylic over WG or BF on my dark royal blue metallic is to die for.
