Yeah, well Mike didn't answer so I guess it's just you and I.
I have the Skorpio sander and it works great, but it consumes so much air my compressor can barely keep up.
I agree. The Skorpio works great but like all air powered DA Sanders, it's requires a lot of air to run it over entire cars. Like this large project,
1970 Oldsmobile Cutlass Wetsanding Project at Autogeek
I am going to sell it and go all electric rather than dump thousands of dollars into another compressor.
My Duetto does a superb job with 3000 grit, but cuts way too fast with 2000 grit at least for my level of skill. (You will never catch me using the Duetto with 2000 grit on OEM paint.)
Using my 21 as a wet sander would make me very nervous. Well, I'm going to try my Mini on my wife's car with 3000 and 5000 grit paper and see how it works.
Sounds like a good plan...
I personally think 12mm is way too aggressive for sanding. Liking maybe levelling some filler or spot prepping a blend area you could use it but for OEM CC?? No sir!!
Even the 8mm in the PC/GG is pretty aggressive.
I agree with all of the above. My guess is that if you research the background for Rupes tools you'll see they have had a longer history of making tools for body shops where guys are sanding filler or "bondo" to prepare a car for paint and in this situation a more aggressive orbit would be fine.
Now Rupes is entering the car detailing industry and bring tools and products used in the body shop industry to this market that might not be perfectly matched. The good news is Rupes is a company that learns from forums and you'll see them make changes in their line that offers tools and products more suited for car detailing as time goes by.
I have never had a machine do better than my hand me in sanding.
I would repectfully disagree.
It's always faster to sand by machine PLUS it's faster to remove machine sanding marks than it is to remove hand sanding marks. I demonstarted this at this year's Mobile Tech Expo in one of my classes and as a live demonstration on Friday and Saturdar after the "Thursday Education Day", when all the classes are held.
I also demonstarted this at my Detailing Boot Camp Classes to all the students by hand sanding and machine sanding the paint and then equally compounding the paint and after a limited number of passes with the rotary buffer, wiping off the compound reside and allowing all the class to inpspect. What they see are the machine sadnign marks are gone and tracers remain hwere the paint is hand sanded.
I will always machine sand before I will hand sand. The only time I would hand sand is in pllaces where it doesn't make sense to machine sand or it's too risky.
One of the hardest body styles to machine sand are antique cars becuase of the built-in body moldkings or ribs. Yet we still machine sanded this Model A just a few months ago.
Pictures: 1928 Model A - Wetsand, Cut and Buff at Autogeek
Here's Matt and Craig learning to machine wetsand for their first time on a 1928 Model A Hotrod...
Notice how well taped-off this hotrod is? That's because it has a lot of curves and edges and paint is thinnest in these areas. The tape not only protects these areas but it's a visual reminder to avoid sanding on these areas.
Machine Wetsanding
After hand sanding the passenger side of the engine cowel next Robert machine wetsand using a Porter Cable and 6" Trizact #1500 Sanding Disc. I trust Robert with any sanding and buffing project we have here at Autogeek as he has years of experience and is incredibly talented when it comes to the art of polishing paint.
Frank's First Time
Here's Frank learning all about how to wetsand, cut and buff fresh paint here at Autogeek's Show Car Garage!
This was Frank's first visit to our Thursday night gigs and he picked an great night to join us as not only did he get to see the entire process from sanding, cutting, polishing and machine waxing a very cool traditional hot rod but he also was able to helps us restore the original paint on a
1956 Chevy Bel Air.
Den wetsanding the curve of the roof...
It's always great to have Den here to help with these projects. Sometime in the near future we're going to have Den's GTO here for a show car makeover.
Big Boys Toys
After getting the feel for how to machine sand using the 3" Peanut Polishers, I let the guys move up to the big boys toys meaning move up to the 6" 3M Trizact Discs on full size dual action polishers. Below Den is using the Meguiar's G110v2 as a machine dampsander.
Finished
There's also a vidoe in the link above where I show the paint is hologram-free after sanding and buffing this hotrod Model A.
I really think Rupes intention with the Duetto was to get people to take out severe defects with wet sanding rather than extremely aggressive pads and compounds, then follow up with a milder pad and milder compound. And I agree with them 100% on this approach.
I agree too... also taught the first Meguiar's Unigrit Machine Dampsanding class to the public on this topic at MTE back in 2010 along with the idea of sanding out defects instead of aggressivley compounding out defects.
Pictures from Mobile Tech Expo 2010
IF you look at the sanding backing plate on the G110v2 the Meguiar's system was so new I didn't even have a
production backing plate at the time of the class, this was a
prototype backing plate and thus it was blank, as in no writing or text on it. Just white paper.
Production backing plates look like this,
Meguiar's Sanding Backing Plate #S6BP 6 inch
Back side
12mm and 3000+ grit works like a charm, but with anything more aggressive than 3000 you'd better be paying real close attention.
Completely agree.
Wet sanding by hand I believe gives u more control of where you want to level the paint. IMO using a machine sometimes is overkill if there are only a couple deep imperfections. Sanding discs have been around forever! I think for the most part machine sanding can be overkill and a rarity. Grab some sandpaper and you'll be find.
I have a wetsanding project coming up and my choice will be to machine sand everything. The only places that will be hand sanded are the places where machine sanding doesn't make sense, can't be done safely and would be too risky. This project is coming up real fast...
Jay's new muscle car projects - Wetsand, cut and buff...
That's just me though...
