xxxc5
- Jul 8, 2009
- 63
WG TSR/FG & PC 7335 Technique
Hey Mike,
So I have finally begun the paint correction process on my Vette closely following the advice you have given me in the following thread I posted:
http://www.autogeekonline.net/forum/auto-detailing-101/21683-corvette-swirls-need-advice-please.html
Now that I am on my way, I have some observations and further questions.
As you predicted, the G100/PC7335 is doing the job, but very slowly, and also requiring MANY section passes. Sometimes I need to go back and do again. I'm using a 5.5 CCS orange pad with WG TSR. I'm using a 5.5 CCS white pad with WG FG. I will definitely be purchasing a new DA in the spring!!!
Now, a couple of questions for you kind sir:
1. PC Speed/Downward Pressure - Being that I have an underpowered first generation DA, am I safe running at 6.0 with TSR? I presume I should be applying as much down pressure possible before the DA stops rotating and starts vibrating. Should I also do the same for FG and how much downward pressure should I be applying? How many section passes per area should I be doing in general for final polishing?
2. Jeweling/Burnishing - Would it be beneficial or a waste of time after I'm finished polishing with FG to go back again with a grey or blue pad polish again with FG?
3. Rough Feel After FG - I've noticed that the finish does not feel smooth after using FG. It's rather rough actually. When I wipe down with QD, the slickness returns. Am I doing something wrong or causing damage?
4. Paint Polish Enhancer - I have a bottle sitting on my shelf begging to be used. Does this product factor into this correction process or should I just reserve using that for when I want to strip old wax/sealant before applying new?
Thanks in advance for your continued support! :xyxthumbs:
Steve
Hey Mike,
Steve
