What a deal!! I wasn't planning on getting a DA polisher, but ...
TechDiver
I was originally not going to get a DA polisher since I am not sure how much I will use one. I started reading a few posts on this forum and many of you recommend them. I just wasn't sure if I would use one enough to spend that kind of money. I was out today and saw an open box Meguiar's G110v2 for a deal I couldn't pass up. It is still new, but the bag is missing. $60 sounded like a great deal to me though. I made sure everything else was still there. Now I will have to buy some pads and learn to use it. It will probably be all I need since I will just use it on my cars.
Tech Diver
Tech Diver
You lucky dog!!!! Thats an awesome deal! I wouldn't care about the bag, I think thats less than half what they sell for on Autogeek.
Sounds like you waked into that one!! :dblthumb2:
Here's some great information by Mike Phillips that will help you.
Foam Pads
Yellow Cutting Foam
- Use this pad to apply compounds or polishes to remove severe oxidation, swirls, and scratches. It is the most aggressive and should only be used on oxidized and older finishes. Always follow this pad with an orange or white pad and a fine polish to refine the paint until it is smooth.
Coarse Green Cutting/Polishing - This foam is of medium density with the ability to level very fine scratches and very light oxidation. Use light swirl removers with this pad.
Orange Light Cutting Foam
- Firm, high density foam for scratch and defect removal. Use this pad with polishes and swirl removers. It’s an all around pad that will work on most light to moderate imperfections.
White Polishing Foam
- Less dense foam formula for the application of waxes, micro-fine polishes and sealants. This pad has very light cutting power so it’s perfect for pre-wax cleaners.
Green Polishing/Finishing Foam - Use this foam to apply one-step cleaner waxes. It is a balance of polishing and finishing that is perfect for all-in-one product application.
Gray Finishing Foam Pad - Composition is firm enough to withstand added pressure during final finishing to remove buffer swirls. It has no cut and will apply thin, even coats of waxes, sealants, and glazes.
Blue Finessing Foam
– Pad has soft composition for applying glaze, finishing polish, sealants, and liquid waxes. Flat pad provides full contact with paint surface to minimize the pressure applied by the user.
Red Ultra-soft Wax/Sealant Foam
- This soft, imported foam is ideal for applying the final coat of wax or sealant. The foam works especially well when applying liquid waxes or sealants because it is firm enough to keep the majority of the product on the paint, rather than soaking it up. The red foam has no cut or cleaning ability.
Super Soft Gold Jewelling Foam - The CCS Super Soft Gold Jewelling Pad is made of Lake Country's softest foam. Use the gold pad to apply a very fine polish or glaze as the final step of the polishing process. Jewelling is the term coined for this step because it intensifies gloss and reflectivity, like a jewel. The gold foam pad also works well for wax and sealant application.
Foam Pads
Yellow Cutting Foam
Blue Finessing Foam
Sweet. I haven't looked up everything on it yet, but you made that easy. I love my electronic devices and power tools. It looks like I may be an autogeek before it is over. This is just going to add many more items to my autogeek wishlist. My wife is going to hate that part.
I think Bobby G and Mike Pillips are, in fact, the same person. Neither ever misses a beat to reply with a helpful link or two.
What is the advantage to using the smaller pads? I guess that is the part I wasn't sure of.
Honestly I have never used one. I just received at forced rotation one. I've heard that the smaller ones are easier to control. An I also think the bigger ones stop rotating much easier which is not what you want. I could be wrong.
Oh, Ok. I appreciate the info. I may get a few that fit this to start off with. I believe I will need 6.5" for the stock backplate. I figure I might as well use it if I already have it.
Smaller, thinner pads are easier to for a random orbital to rotate, which means it's easier to get correction with them.
