What a great way to kick of the 2013 detailing season! Trashed e46 M3!
zmcgovern45
This 2002 M3 was purchased fairly recently by it's owner and was in need of a great deal of work.
The exterior of the car was in need of the most work. It was covered with swirls, RIDS (random isolated deep scratches), rock chips, clear coat etching, water spots... you get the picture. The car was washed with a concentrated mixture of citrus wash to help remove any protection that was still on the surface. Next, the car was decontaminated with clay... this was one of the most severely contaminated cars I have dealt with. When performing the "plastic baggie test" it felt like 500 grit sandpaper. After clay, I proceeded to tape off any trim or external features that may be prone to damage during the polishing phase. Next, I carried out a series of test spots on the hood of the car until I found a process that I was happy with. I was not after 100% correction, as this is not a show car. I wanted to find a 2 step process that would remove moderate defects and still allow me to finish down with only 1 finishing step. I would say overall correction was around 85%, which is typically a bit lower than a 2 step process usually yields, but this car was covered with pretty severe defects that simply were not worth chasing after since this is a daily driver and has very soft clear coat. After correction, the paint was coated with a layer of glaze, sealant, wax, and then a final wipe down with spray sealant. The results are an incredibly glossy, clear finish. A HUGE improvement from what I had started with. The pictures can attest to that!
Process
Exterior
Wheels: P21S Wheel Gel
Tires: Tuff Shine Tire Cleaner
Wash: CG Citrus Wash and Gloss (diluted to strip previous protection)
Dry: DI Waffle Weave Towels
Clay: Opti-Eraser (Heavy) on horizontal surfaces, Fine Grade Clay on Vertical Surfaces
Paint Thickness Readings Taken
Compound: Menzerna FG 400 with Microfiber Cutting Disc (M105 + Surbuf Pad used on Heavy defects on hood)... Pads prepped with CG Polishing Pad Conditioner
Polish: Menzerna SF4500 with LC Crimson Pad
IPA Wipedown (Diluted at approx. 13%)
Glaze: CG EZ Creme Glaze
Sealant: Menzerna Power Lock
Wax: Menzerna Color Lock
Final Wipe: CG V7
Tires: Dressed with Optimum Opti-Bond Tire Gel
Exhaust Tips: CG Metal Polish + Protection
Glass: Invisible Glass
Interior
Vacuum Entire Interior
Leather Wiped down with Meguiar's Leather Cleaner + Conditioner
Dash and Trim wiped down with 303 Aerospace Protectant
CG Stripper Scent used as Air Freshener
Engine
Entire engine bay sprayed down with Meguiar's D103 (diluted 10:1)
Scrubbed with various brushes
Rinsed and wiped clean
Dried with MF Towels
Metal was polished with CG Metal Polish + Protection
Engine Covers and Plastic Covers were dressed with 303 and/or CG Back to Black
Total Time Invested: Approximately 13 Hours
Before
^From a distance and in low light, it doesn't look too bad
^Upon closer inspection, you can see that the paint was quite dirty
^The wheels were pretty dirty as well
During
^Wheel cleaner going to work. Releasing the built up brake dust and dirt that covered the wheels.
^After washing I was not surprised to find left over polish or wax in just about every crack and crevice.
^ You can see more left over wax or polish, as well as some of the swirls on the hood. They were very easy to see even without proper lighting.
^Opti-Eraser (heavy) used to decontaminate the hood, as it was in terrible shape. It felt like rubbing your hand over sand paper.
^Clay was used on the vertical panels, as they were not as bad as the horizontal surfaces, but they were obviously still quite contaminated.
^This close up picture reveals the true condition of the hood. It was a disaster. RIDS and Swirls everywhere
^Even without direct lighting, you can easily make out the swirls everywhere
^Every panel looked like this, or w
^Severe road rash/rock chips in front of the rear wheels... no way to fix that with polish
^Car is taped up and ready for testing on the hood.
^After a few combinations, I settled on my correction process. You can obviously see the improvement! This close up shot allows you to fully appreciate the change in color after correction. The paint is now a deep black instead of the oxidized greyish black that it was previously.
^50/50 Hood
[video=youtube_share;dWk4m4ViEZM&list=UUYYkJ7ziLLPtmrrESuYUoPw&index=1"]M3 50/50 After Paint Correction - YouTube[/video]
^50/50 Hood
^After compounding there were still some heavy scratches that remained, so I needed to use a more aggressive 3 step process on this central part of the hood. M105+Surbuf Pads were used to remove these scratches.
^Hood after compounding. You can tell it has a slight haze to it. This is to be expected after compounding, which is why it must be followed up with a finishing polish.
^Fender Before
^Fender After
^Door Before
^Door 50/50 - You can see that plenty of deeper scratches remained, however it is not reasonable to chase after all of these deeper scratches on a 12 year old car that is used as a daily driver. The improvement is still amazing!
^Door after compounding
^Passenger Side Before
^Passenger Side After Compounding
^Sealant drying (left to cure for 1 hour)
^Exhaust tips before polish (these had already been washed, but they were severely oxidized)
^Exhaust tips after polishing
^Engine before
^Engine After - cleaned up and dressed to a nice, black, new looking finish
After
^Hood right after removing the wax (This is after correction, glaze, sealant and wax)
^The entire car was then wiped down with V7 in hopes to remove any remaining product I may have missed and to leave an incredible finish. Here are the results!
^Very glossy, and much deeper and darker! A true black now!
^Like a mirror
^Unfortunately it was raining so I did not get any shots outside... it is going to stay in my garage one more night with hopes that it will be clear tomorrow. Don't want it to get dirty right away!
^All cleaned up!
^Clarity fully restored. Truly like looking into a mirror.
^Some, but certainly not all, of the products used on this car.
Thanks for looking!!
Please leave your thoughts/comments below!
From trash to treasure......gorgeous!! :props:
Thats better then new and what jet black is supposed to look like :xyxthumbs:
Wow, very impressive. I'm sure the pictures just don't do this detail justice vs seeing it in person.
Great work car came out amazing.
Thanks!
:buffing:
^Still far from perfect, but a big step in the right direction! Thanks!
Incredible turnaround...you should be very proud!!
^Thank you, I was very pleased with the results! Hopefully the owner shares the same feelings :xyxthumbs:
It really looks great in person!
Amazing turn around with unbelievable results. Thanks for sharing.
Chris aka Italian Guy
Thank you!
Car looks like a Million bucks!! Nice
^:dblthumb2:
love the camera work, great job!
^Thanks! Perks of being both a photography nerd and a detailer!
Awesome job! I love me some e46 m3s
^Awesome cars indeed!
Very nice work. That thing was hammered and your brought it back to its proper glory. Looks incredible.
^:righton:
Looks awesome!!!
^Thanks!
:eek: Yikes it was in bad shape!
Stunning turnaround :applause:
I'm sure the owner was very pleased.
Personally, what I am most pleased to hear is that the current owner is not the one responsible for neglecting the finish for that long.
You really brought back it's youth. I sure hope that the customer is not only happy with the result, but that he continues to bring it back for continued treatment.
From looking at the first pictures it looked beyond help. But now it looks like it's got another 20 years in it.
Great job. I see that you have cg pad conditioner spray. It's the same as cg luber. The pad conditioner doesn't come in a gallon as far as I know so if you need to refill it, just buy a gallon of cg luber.
