I am trying to do some paint correction to remove swirl marks but can't seem to get them out. Here is what I have done so far. Washed the car, taped off the car, clay barred the entire car.. paint feels like glass. Then I used the 3m perfect it kit and chemical guys pads and the Griot's Garage 10813 DA. I started with the #2 medium polish and a green pad as a test, this had no effect.. then I moved to the #1 heavy compound and orange pad, still swirl marks.. so I changed to the most aggressive yellow pad.. this seemed to reduce the heavy swirl marks but did not remove them completely. I decided to buff completly out using the number 2/ green pad combo and then finishing with the #3 and blue pad. Here are my results.
As you can see the swirl marks are still there.. I watched the video Mike made on polishing and followed it step by step.. Do I need to try a different type of polish ?? more aggressive ? This is on a 2013 C63 AMG, it is not supposed to have the Mercedes Ceramic paint.. I was told by a detail guy that if it did there would be a C in the vin which this does not have..
