What am i missing?
Blackalak
As you can see within my picture I am getting this hazing effect after a 4 step polish using chem guys v series (all 4) and 4 pads with rupes 15 lhr not sure what stage needs more polishing to get rid of the haze? any help would be greatly appreciated!
What kind of car is this? What pads are you using? Have you tried any different compounds/polishes?
Orange with 32 white with 34 blue with 36 black finish
How many passes, and at what speed is your machine?
The cutting step, it seems, is not working. It also seems that the pressure you're putting is a bit too much, you are starting to burn the corners. It looks like marrying inflicted by wool with a rotary.
CG V series is not a mature product, to put it mildly. I would use Menzerna FG400 or HD Cut. Audi usually has hard clearcoat, therefore, the cutting stage is very important to get it right, or else you overload the following stages.
I think, imho, the biggest problem is your choice of polishing compounds; Menzerna is the way to go with german cars.
:iagree: You can't go wrong with Menz FG400. The hex logic pads from CG are crap too.
I def agree on that one, one pad fell apart after one whole car I pretty much followed their instructions 1 pass slow to spread then 3 passes at max speed mid pressure till product became clear
Agreed. IMO that's mostly likey just products that aren't doing a damn thing or possibly poor technique. I'd wager on the products. I mean come on... 4 steps these days? Products have come such a long way that you barely need 2 anymore. FG400 is what you need. It puts everything else to shame.
I am also a huge FG400 fan for wide application scenarios. Audi paint would most certainly get it after my test spots tell me to get stronger. Another thing is to very carefully inspect the paint after each test spot and see what you're left with.
If you are trying to finish this vehicle with the products you already have... I wish you the best of luck.
If the initial compounding step is removing the level of defects you are after than you really just need to focus on your finishing system. Out of your pad and product selection you'll need to find the next step that removes the compounding haze and brings back the gloss. Forget about the "4 step" instructions. You need to perform some test spots and see what the paint likes.
If none of the products work to restore any gloss than I suggest selecting a higher quality abrasive such as M205 (non-diminishing abrasive) or CarPro Reflect (diminishing abrasive) for final polishing. I've used both on several A7s and both have worked equally well in my experience.
Just to chime in...
A few weeks ago I started a poll and asked
Mike Phillips said:
POLL - What's the number one most important factor when it comes to polishing paint?
1: Technique.
2: Tool.
3: Pad.
4: Paint.
5: Abrasive technology.
Which one and why?
The number one reply was technique.
Here's the link.
My answer was and always has been,
Abrasive technology is the number one most important factor when it comes to polishing paint.
And the replies by most in this thread would tend to prove me right.
Some say technique and they're entitled to their opinion but from my experience, it's the abrasives that are touching the paint and the first most important aspect of any paint polishing project.
wow! so much help here i appreciate all of everyones input here, looks like I'm going to have to do some test spots to see if i can bring the shine back even more, like i said the "haze" can only be seen in certain angles of sunlight and under very high luminance artificial light smh in normal daylight if you are not looking close it looks amazing but I'm a perfectionist... and anal with my own car haha
did you use 4 pads for each step, totaling 16 pads?
Or did you use 1 pad for each step, totaling 4 pads?
Just to chime in...
Here's the link.
I see what you are saying, but without good technique it doesn't matter what kind of abrasives you are using, the results will be off bc of the poor technique.
I agree. the CG polishes aren't so great.My experience with Rupes is that it works best with flat pads too
Ok I have held off enough. My opinion was Technique also in Mike`s poll.
I am going to quote the Master that I have nothing but extreme respect and appreciation for all the knowledge he shares with all that want to learn and be proud of a task well done.
Page 8 in Complete Guide to A Show Car Shine regarding hard/soft paint. You need experience, Nothing beats first hand experience, Your personal skill level has huge influence with success or failure.
There is so much to learn and Mike you are the man if I am off key please advise. Now just a couple more quotes.
Technique is more important than the products and pads you`re using, You can have the best products and best tools available but if your technique isn`t exactly right, you won`t get the results that you`re after.
I have read Mike`s book so many times pages are coming loose from the binding.
Personally, without good tools and products, technique doesn't matter and vise versa. This might be a case of residue control or by the pic it may even be your machine not be turned up enough to spin properly. Watch a few more videos about buffing and polishing, you'll get it, takes practice :)
Good luck.
