What are your must have detailing products?
PoorBoys pro polish
PoorBoys pro polish II
PoorBoys EXP
MeGuires ultimate compound
MeGuires ultimate polish
MeGuires ultimate wax
Collinite 845
Plus many more to name
Ed
:auto wash: :buffing:
Grit guard
Foam Cannon
Numerous safe wash mitts
Daytona Wheel brushes
LSP of your choice
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Here's mine.
M105, even though I've replaced it with the WG Über Compound I'll still need the 105 for those really trashed out cars, deep swirls, scratches, the 105 is one of my products that's needed, maybe not often but I guarantee you there will be a time I'll have to dig it out of my detail bag.
M205 is what I use to maintain my black RAV.
It works well with either the orange or white pad , I mostly use it using the white pad either to use to polish when light swirls are found, yes if the swirls are shallow it can and will remove them.
I find it to he the best ultra fine poish on the market and works miricals following an aggressive compound, leaves the paint smooth and flawless, when it comes time to buff off it's so darn easy, no worries about it gumming up on you, removes like a wax. :dblthumb2:
Wolfgang Paint Sealant
My new found love, the first time I used it I was besides myself after I buffed it off, it leaves the paint so slick and the gloss is second to none.
It's one of those products that using it for the first time makes you sit on a stool and say wow over and over:)
Wolfgang Trim Sealant
We've all used dressings to make our trim look better only to wash off the next time you wash your car, well not with the WGTS , it last and last, it leaves your trim looking new and beads like a wax.
I applied it on my trim about six weeks ago and it still looks like the day I applied it, not many other products will give you the same results.
Chemcial Guys Mr.Pink
IMO washing our cars is the most important thing we can do to keep the paint looking it's best, it's the first step we do before we can do anything else, paint has to be really clean before we can touch the paint either with a wax or doing a full paint correction.
For those who own a black car we all know how bad the water spots can be after washing.
Mr. Pink is now my ONLY car soap I'll use from here on out.
Since I started using Mr.Pink I found the water spots aren't nearly as bad as with other soaps I've tried.
I will most likelly forget some, but:
- Meguiars NXT
- Carpro reload
- CG new car high shine
- microfibers
- cobra ww
Here's mine.
:goodjob2:Great post. You could have added Uber compound also. Feel free to share your thoughts on that also. I haven't used it and would like to know some more about it.
Water is real....I saw some today, with my own eyes.
Who was the manufacturer of the water? Do they provide a MSDS sheet?
If Autogeek doesn't sell it. It doesn't count anyway.
This indicates that AGO acknowledges that water exists...does that count?
Results for water - Search
And the survey says! XXX
No.
If I give you water then its a slippery slope to air, light, gravity and karma. Then next we will have to deal with the laws of physics, work, celestial body's and chemistry. It will be anarchy. Dogs will be sleeping with cats. Frogs will fall from the sky. Up will be down, down will be up. To save all this from happening and maybe humanity itself. I must in all good conscience say no to water. (actually I had to go run it by my manager in the back and he said no).
I have to give it to you though. :applause:The acknowledgement part was epic.
My "must have" detailing products, assuming starting with a clean car:
1. Clay Bar
2. Meguiar's 105 Mirror Glaze Ultra -Cut Compound
3. Meguiar's 205 Mirror Glaze Ultra -Finish Polish
4. Meguiar's 9 Mirror Glaze Swirl Remover 2.0
5. Meguiar's 7 Mirror Glaze Show Car Glaze
6. Meguiar's 21 Mirror Glaze Synthetic Sealant 2.0
7. Meguiar's 26 Mirror Glaze Hi-Tech Yellow Wax
8. Meguiar's 135 Mirror Glaze Synthetic Detail Spray
Hope this helps.
Roger T
1. Clay Bar
Hope this helps.
Roger T
If it's "Clean", why do you need a Clay Bar?
Clean means clean, without any dirt. It doesn't mean without contamination...
Let be nice. Especialy since that was his first post.
This is not the Spanish inquisition. There are no wrong answers.
Instead of saying clean he probably should have said washed. But the meaning was pretty clear.
Just having some Fun...no offense intended...no emoticon needed
You can wash your face with soap and water and rinse well.
Your face is clean but it is not smooth because you have not yet shaved. By shaving, your face is now clean and smooth as well.
In the same way, you can wash your car with soap and water and rinse well. Your car is clean but it is not smooth because you have not yet used your clay bar. By doing the the clay bar process, your car is now clean and smooth as well.
Hence my statement "....assuming a clean car, my needed items are: 1.Clay bar.............."
Roger T
5 must have products....... Give me Malco red thunder, glass cleaner concentrate, Malco nano care 1 step machine polish, Malco clear acid, a&l cosmoline remover. Hey if I only could have five products these basics could get the job done anywhere anytime!
