JDGolden
- Mar 16, 2013
- 1,737
- 288
Negative. Just the NA 3.5. I am really torn on the ecoboost engines. Thanks for the compliment. In the next month or so I’m going to lightly polish the paint and use DoDo Juice purple haze on it.
Fuel pumps scare me. My Audi has a recall on it.
I use premium in my Cadillac too even though it calls for regular. I figure it can’t hurt.
Man I wish it was only 15cents here. 93 is always 60 cents more than 87. Don't have much 91 at all around me in SE Michigan. My GTI says regular is okay but it gets premium.You sure it calls for regular? Iirc all my pre 2000 Cadillacs called for premium gas.
I’m the same way with those cars, I’ll put premium in it regardless. It’s only about a 15 cent difference from the lowest octane.
Sent from my SM-G975U using Autogeekonline mobile app
Oh yeah I only use premium. I wouldn't be surprised if in the 13k miles before my ownership regular was ran though. How many miles are you at these days. I'm at about 18,300.Regular is ok but it will run at reduced power. If you want all the power you can get from that engine you should continue using premium. That's all mine has ever seen, premium gas from a top tier station.
21,068 miles right nowOh yeah I only use premium. I wouldn't be surprised if in the 13k miles before my ownership regular was ran though. How many miles are you at these days. I'm at about 18,300.
I just finished my detailing yesterday, took my time and needed 5 days to finish. Decontaminated with iron-x and auto scrub, wash of choice was McKee's 37 Coating Prep Wash. Corrected most defected with orange pad and Griot's Correcting Cream (had to use microfiber pad and Fast Correcting Cream in a couple isolated spots due to VW hard paint). Then went over the entire car with Rupes Yellow pad and CarPro Essence. Coated everything with CQuartz UK3.0 then Gliss v2. Dlux on textured trim. Looks great in the garage, Wednesday it will be sunny so I might bring it outside to look at it, hopefully no high spotsNo pictures because I'm lazy and there wasn't anything to be that excited about and show off. However today started my spring detail. Broke out the pressure washer for a decon wash. Cleaned up all of the plastic and rubber trim with Power Clean 5:1. Car was then washed with Reset and about an oz of PC for a bit of extra stripping power. Rinsed then got a spray down with Tar X and then rinsed. Wasn't a whole lot of tar. Tried out Gtechniq W6 Iron remover. Smells of course but wasn't overwhelming. Wasn't as much fall out on the car as I expected. A bit on the lower panels and of course the hatch was a bit more contaminated. Went around and spot clayed. Paint was still very smooth and contamint free.
Next day or two is supposed to be a bit cold for my liking so probably in a few days I will be giving the car a light correction. Hasn't been done really since in the 5k miles I've owned the car. It did get a very light polish just to clean it up a bit when I bought it.
The only good thing about Covid is that I'm not going anywhere so I can take my time instead of doing it all in one or two days.
Bruno,
You stated use the Carpro Quartz UK3.0 and then Gliss v2. Did you do only one coat of each, or have you tried two layers of CQuartz then a topper?
Curious
Kirby
Alright...new tires/wheels, do you have a guy MercWashed both the Fusion and the Focus this morning.
Used Griots 3-in-1 Ceramic Wax as a drying air and was impressed. It really made the flake pop on my Wife's Focus.
I also noticed that someone scuffed the he out of the passenger side if my Fusion since I washed it last weekend. I also noticed that my tires are finally at the wear indicators, and that one of them has a screw in the tread.
Time for new wheels and tires? As Roger would say, stay tuned.
Sent from my SM-G986U using Tapatalk
