MisterSnoop
- Sep 15, 2020
- 2,302
- 558
To chilly:
Well, finally got around to using Dr. ColorChip. Like, a month later! Here's what happened.
BUT FIRST!!!...I must confess.
This particular chip was the direct result of me doing something so incredibly stupid, it wouldn't surprise me if I got booted from this forum.
One winter night after a snow storm, I went out to clean the cars. There was a layer of ice that had formed and crusted over the first snow. I used my neighbor's shovel to remove the excess snow from most of the car, but I miscalculated the depth of the snow on the pillars...and I *barely* dinged the car. Yes, the shovel had a metal strip along the leading edge.
**SHAME**
First pic is of the chip, cleaned out as best as I could. It's very shallow. The paint that flaked off had to be thinner (much thinner) that the shell of an M&M.
2nd pic is during the paint process. I used the rubber squeegee to scrape across the filled area, but it ended up removing a lot of paint. Then I did the "dab & smear" technique but that leaves a lot of paint around the surrounding area. This picture is either my 4th or 5th attempt at covering the chip. You have to add many layers to fill the chip to the level of the rest of the paint.
OR...
...you can glob it somewhat heavy, let it dry more than the 2-5 suggested minutes, then lightly start to wipe away with the SealAct solution. This seemed to work well for me.
Last pic is the final result. Definitely not bad!
This chip was easily the biggest eyesore, and it took me a while to mess with it to get it right. When I have more time I'll attempt the other smaller chips.
PS - my pics still suck on Tapatalk. Sorry!!
I don't think Dr Colorchip really intends for it to be completely level when you're done applying it, more so that the chip isn't noticeable from a few feet away.
