PA DETAILER
- Mar 5, 2011
- 6,017
- 251
Maintenance wash on the ZR2. In the SUN. LOL. Finished with flex wax as the drying aid Whole new respect for the product.
If that's for me I tried doubling up a couple weeks ago. I put on a Carnuaba Arts (Graphite Gray) and then added High Gloss. Pretty sure it is overkill but I got a little order happy once I joined their mailing list and started receiving the 15% off codes.What PA are you using for LSP?
So yesterday I finally got in to my buddy's graphics shop for some "tweaks" to the EN. I can honestly say the rearend of the car is done (unless the O.E. Aussie foglight is "reasonable) I had them use medium smoked LaminX for the back-up lights and a sliver of black satin vinyl to seperate the body of the letter i from the dot. Speaking of that dot, it's been treated to some red vinyl. Now if you look over to N logo, it already has red and black in, now things tie in nicely. I can't wait to hear "what's an i30"
So today is a special C&C, not just because it's Father's Day (Happy Father's Day to all you guys BTW) but it's at a different location, which means different cars. It's at a local, higher end grocery store called Mariano's. Apparently someone is a manager at one of the locations and is apart of the Chicago Garage forum. The last show was really cool, looking forward to this one today.
So I got out there early this morning, about 5:15 a.m. I did run the EN through a touch-free yesterday but the trees are still spraying and before I went to bed I could see it, so I knew I had to get after it early.
I started with 4 oz of P&S Pearl and 2 oz of CarPro Restart in my Griot's Garage foam gun and foamed it down, emptied the bottle and let it dwell, it was 50 degrees so I wasn't too worried. I then grabbed the Brake Buster in the IK Foam 9 and took care of the tires & wheels, all brushes used, CLEAN!
I then rinsed everything down, great beading so I added to it. Grabbed my other IK foamer that only has Griot's Garage Poly Gloss in it and foamed down the EN with it and let it dwell. I rinsed it down, then used free flowing water to flush things out.
I dried the EN with a CG's towel I got for Christmas, dried the tires & wheels with 2 designated mf towels and gave the engine bay a little wipedown, clean as you go I say!
I finished up by spraying some Adam's under carriage spray in the wheelwells, applied some Griot's Garage leather scent in the interior and applied a very light coat of TWHS graphene tire dressing and now it's ready to go
Once again, Happy Father's Day to all the Dads out there and if your spending the day with your Dad appreciate the time, not all of us are so lucky![]()
Tried out a DIY ghetto pad washing station I put together.
Handypail paint roller tray + el cheapo 6” backing plate + Griot’s drill adapter bit + drill (ok, bit driver).
I’m too cheap to buy a pad washer, but have been curious to find an alternative to the hand scrubbing step. Also haven’t been crazy about some of the grids the pad runs on for some pad washers; seem like they’d be sharp to the pad. I know if they wrecked pads we’d have heard about it long ago, but I like the idea of something rounder. The other day in the garage I saw a paint roller tray which got me thinking.
The trays I have are either very paint-y or super flimsy. Found the Handypail one during my search, I think it was like $12. Actually quite sturdy, and another benefit I found when I got it home is they made it to sit securely in a utility sink.
Backing plate was a cheap on I could source locally (sorry AG, I’m impatient when I’ve got an idea to try). $8.
I’ve had the bit adapter for a while now, I use it to run carpet brushes on my drill. $10
Add about 1/2-3/4 gallon of water and detergent (I’m trying rags to riches), and then run with about half the pad in the water. Tray is sturdy enough to squish on to help flush the fluid through. Went through a big backlog of pads I had to clean in waaaay less time than it would take to clean by hand.
Future upgrade: since the backing plate I got is 5.something inches to run 6” pads, I’m going to look into making a disc to put between the backing plate and the outer edge of the pad to: keep the velcro away from the 5.5” pads that overhangs their backing, and to support the outside of the 6.5” pads. I’ve got some lexan at work I’ll see what I can come up with. No damage that I noticed with the stack I did, but figure can’t hurt.
That is some Mad Scientist stuff right there, John!! Awesome! :dblthumb2:
Oh, nothing too crazy my friend. Just laziness + … thriftiness (cheap sounds so… cheap. :laughing: )
I really like how big the ribs are for scrubbing the pads - I’d say they’re about the thickness of a pen. This setup + Rags to Riches brought 18 pads/applicators (not all pictured) back to fresh and clean.
Some of them had accidentally gotten tucked away with Blackfire OneStep still in them (I’m afraid to show the before pictures for fear of losing my ‘Geek card…), but they’re all good to go now. I did run them through a pass in the washing machine for good measure.
Just noticed they also sell a plastic paint grid in a similar style that is made to hang in the side of a 5 gallon bucket; not sure it’d be the most ergonomic/convenient for pad washing that way but might be good to have to throw in a utility sink. Less than $10.
I love this. Did you just choose to use the drill+adapter method for the ergonomics?
Any reason just running this method off the polisher machine wouldn't work?
Haha, ive experienced that a bit my first time using my lake country 4000 pad washer. I wish it had some sort of shield or something that helped to block the little bit of slingJust make sure you get a feel for where the wash-water-sling is gonna go before you really pull some trigger.
Um, I've heard. :laughing:
I'm sure you could use the polisher, I just wasn't super excited to run a machine near water plugged into the wall.![]()
Yeah, I'll be making a shield for at least one side of mine.
When you fab one up, post it up if ya wouldnt mind. Im curious to see how it will work out
