BudgetPlan1
- Dec 21, 2015
- 2,162
- 248
This evening I said “Nope, nope & NOPE” to an octopus tentacle:
Sent from my iPhone using Tapatalk Pro
The metal panels pop and bang when it's windy, which should stop now, and when it's hot outside the metal panels act like radiators, I'm not sure how much difference it will make on cold days, but we don't get below freezing much. It'll also be quieter when I'm using power tools.
I'd avoid it just because they are so smart. I'll stick to eating dumber animals.This evening I said “Nope, nope & NOPE” to an octopus tentacle:
The start of the winter bare root season this year has been slower than usual. The first delivery from Flemings's arrived at 7am yesterday, of which 600 assorted ornamental and fruiting trees were sorted, labeled, orders pulled and then lined up and buried in sand. A process that took just on 8 hours to complete.
Circa 9am.......................
Eight hours later.....................
A number of varieties were not sent in that initial Fleming's delivery, so there will be a couple of follow up deliveries to follow. The majority of our fruit tree assortment will arrive next week from a secondary supplier. Roses and our yearly allocation of citrus trees typically arrive late June or early July.
5 hours of mowing, weed eating, and clean up
Because I was a good boy I’m rewarding myself with a chuck roast on the grill
I am afraid I am losing a very expensive spruce tree we planted last August, it did not do well over the winter
The maple trees and larch trees are fine, but the spruce is struggling and I don't have enough expertise to know why
The funny thing, that lawn would still need mowing in Australia. Scalp or go home is the norm here. :laughing:
Are other plants around this spruce growing well, or struggling too? If so, then I would have the soil pH tested. This is pretty easy to do via a kit or take a sample to a local nursery and is easy to correct if the soil is excessively high or low. Research suggests spruce like a slightly acidic soil, between 5.5 to 7.0 and can be slow to grow with pH levels above 8.0.
Important to note - if the pH is incorrect, no amount of fertilizer will get the plant to respond, the soil locks up the nutrients and prevents the plant from accessing these nutrients. This is usually witnessed by the plant slowly going backwards over a period of time. You must correct the pH beforehand. This is something a lot of customers don't understand or can't comprehend, even after having this explained to them. :bash:
(I have a lot of cross-over in terms of pH with my day job and hobby. Knowing what acidic-neutral-alkaline does to plants is just as important as what that will do in terms of cleaning abilities.)
If the pH tests ok, then I would say that the root system has not developed as it should. This could be from being root bound when purchased and the plant has stayed where it's happy rather than developing a root system beyond the potting mix it was initially grown in. Again, you don't want to excessively feed the plant as it's clearly stressed, same thing when a human is sick, so mild applications of a root stimulant (we have a product called "Plant Starter" for this, which is an indole acetic acid) but you can also use a seaweed type product. Think of either as a multi-vitamin for plants, they are a supplement for overall plant heath. Once the plant improves in colour or shows sign of new growth, then go in with a heavy feed.
If the plant fails to respond, then put the axe next to it! Sometime a little fright will get a response! :laughing: Seriously though, sometimes you get a dud plant from the beginning. Considering you are in summer, I would do the above treatments and see what happens. By the end of summer/early fall, if they plant has not responded, pull it out and start fresh, in other words don't waste years reviving a plant that compromised from the start.
All the lawns around here were done by the same hydro seeding company and all use the same Alaskan grown seed mix
The other houses look like hell because they scalp their lawns and this mix is meant to be cut 3”-4” tall, so that’s what I do
Plus I haven’t seen anyone else fertilize either
If you like seeing Chris Hemsworth not playing the hero you should check this out. It's one of those films where you don't really know where it's going to end up.Went with some friends to a Little Big concert. Not my cup of tea but was actually pretty entertaining.
Think I’m done with concerts. Feet and back didn’t like all that standing around.
Went a couple days ago to see Furiosa in D Box (seats move and vibrate with movie. Car scenes were cool).
Movie was good and action scenes were great…. Chris Hemsworth did a good villain.
I also ordered a watch opening tool, I'm sick of paying $50 a pop to have someone replace a $10 battery in less than 5 minutes. At least G-Shocks you can generally do yourself.
