I'm a one man show and I can tell you I wouldn't do that job without atleast 2 others that knew what they were doing, polishing the sides is very hard to do while in the water. Since the boat probably doesnt get waxed that often id go with a one step cleaner/wax probably megs marine cleaner wax for its ease of use. Charge no less then 1500 if all your doing is polishing from the waterline up, gl that's a big job
thanks for the helpGood luck! Remember, do not wax the non-skid surfaces or grab rails. Slick is bad on a wet moving boat Although the size makes it intemidating, its all of the nooks and crannies that make it a pain. Start there and work your way out, like painting a house. After that the big surfaces will seem easy. There are even enough surfaces there that you can play with waxes for different shines.
I like the Collinite fiberglass cleaner for spots and Fleetwax for the surfaces. Seabrite makes a nice liquid cleaner wax also available at most marine stores.
No wax in the engine room!
:iagree: :dblthumb2:
Couldn't agree more with what you said. ATLANTIC CITY HUH? I am about 2 hours from there, if you need any help I'd be more than happy....of course for a price.![]()
