what do u guys think of this foam gun
Not familiar with that unit. Hard to see how it mounts, or is triggered. It looks like one that snaps into/requires a pressure washer, compared to one that hooks into a garden hose. "pretty decent price" is only so if the unit serves your needs, and is made well.
At the end of the day, it's important to be sure it connects as you wish, else, you will be left trying to figure it out after the fact, or get stuck with something that won't serve your needs, which is a waste of money and time lost trying to make it work.
Good luck.
Since I'm not a fan of any foam-gun,
I think you should save your money.
looks like a re-branded sm arnold super speedy foamer (around/under $50) - just keep in mind this is for use with a pressure washer..
^ some feel that using (foam cannon/gun) car soap as a pre-soak to loosen dirt/grime isn't really all that effective (or beneficial) and would rather use a pressure washer to blast all the dirt/grime off before starting the wash process...
I think they all do the same thing, shoot foam.... lol just another way to rebrand and make $$$
the wash process...
Or, if no pressure washer is available:
-some will use the hose/nozzle to first
spray down the vehicle before washing
-some will use RWs/WWs.
