What do you pros use to remove glue behind Decals??
megs body solvent does not have good reviews, says its for light duty use and dont remove really heavy glues or tars. like i said just use tarminator and be done with it. or atleast anything d-limonene based.
Tarminator or 3M Adhesive Remover. If those don't work, fire is next...
Tried Terminator, it WORKED!!!!!! Let it sit for 60sec and I could take off the glue with my finger nail. ONLY thing I'll ever use! Lacquer thinner, silicone spray, goof off, goo gone, and ace-tone didn't work at all. All were left to sit 60sec aswell. Also the glue I had wasn't regular glue.. It was under cracked decals for 5yrs cooking in the az extreme heat. Was hard as nails.
3M adhesive remover. Tarminator is good but I only use that on tar.
I bought a can of 3m adhesive remover, didn't use it because tarminator worked great, but I'll try it to compare Monday, I'll let you guys know how that goes.
Sent from my iPhone using AG Online
Any good steam cleaner will peal it off right off with tape.
Touling (I think I spelled it right) it is the ingredient in adhesive that makes it sticky. If sprayed on adhesive sill totally melt it away. Any paint store will carry it. Works awsome.
klasse AIO, clay the area reall well while you clay the rest of the vehicle, continue on with detail as normal.
I was in a similar situation I tried using wd40 and goo off with no luck. Ended up buying 3m adhesive remover and was shocked on how well it removes the adhesive.
Tarminator worked better for my situation. Tried both.
