Kyle_Elantra
- Jun 13, 2013
- 353
That's true...I don't have one so I didn't even think about it.
Does anyone charge over $60?
Also how often does everyone actually do headlight restorations?
Depending on how bad the headlights are you are looking at 2-3 hours of labor plus expenses (gloves, IPA, masking tape, polish, sand paper, etc).
Why does it take that long? Even doing them with hand sanding it rarely takes more than an hour...
Critical Details, thanks for the long responses. Also on how often I meant how often you get customers, not on each specific vehicle. Which I hope with using Opti-Lens that it lasts a while..
I practiced on my fiance's car last week. It took me a while to do a quality job like you mentioned. Although I didn't wetsand all stages except the 3000. Maybe I should try wet on all the others to speed it up as I noticed sanding did take a while.
Also for speeding it up. Do you think switching between each headlight on each step is more productive or doing one headlight start to finish? As in sand with X grit, switch to other headlight and sand with X grit, and then once you're ready for the next step switch grits and repeat process.
Yeah I'm thinking of still lightly covering the front end of the car with a sheet/etc. even if it is dirty, but still doing a quick wipe down with a Quick Detailer so I have less of my mess from the process to clean up.
You're welcome. I have three sanding pad interfaces and keep a different grit on each one (800, 1500, 3000). I perform all three stages of wet sanding on one headlight and then switch to the other headlight. Once all of the wet sanding is performed I compound and polish one headlight at a time.
I only perform a handful of headlight restorations a month. Half of the time a customer will buy a stand alone Headlight Correction and the other half it is an add on service.
Do you charge different if added on to another service?
Also do you see a difference in scratches removal between jumping from 800 to 1500? I did 800 dry, then 1000 dry, and then 1500 dry, and finally ended on 3000 wet. 800 took a while to remove the oxidation so I ordered some 600. Maybe I need to just do all wet to reduce grit choices?
Do the headlights that you restore in an hour look this bad? I spent just shy of three hours restoring these headlights.
[ame=http://www.youtube.com/watch?v=ACu1yRyjzOU]Car Detailing: Headlight Restoration - Honda Civic, GoPro Hero3 - YouTube[/video]
This was a great video! Always learning something new here on AGO.
Thank You Critical Details for the video and awesome work
Critical,
Great job on those! Yes I've done them in that poor of condition, and I've done them that large, but never both. I also don't OC in the timeframe I mentioned. It looks like you do a very nice service for your customers and I hope you're able to make money doing so.
In South Jersey pending on the condition of the lights. I usually start around $75 - $100 that includes all major lights only (head, tail and fog lights.) I wet sand by hand then finish up with some polish. If they are really bad and it's gonna take too long to wet sand by hand I keep a 3M kit in my inventory. I bill the additional cost of the kit to the client.
I use a plain paint sealant and offer Opti-Lens as an up sell. So starting at $75-$100 your getting at least 4 lights done, 6 if you have fog lights. It's rare that you come across damaged turn signal lights or break lights.
You have to make sure you are covering your expenses and getting paid well for your work. Don't forget you have to tape out. That's an expense. Make sure you roll that cost into the job.
Do the headlights that you restore in an hour look this bad? I spent just shy of three hours storing these headlights.
