What does everyone use to remove wax?
I think anyone considering the FK1 Decom kit #1 should understand that it is an acid. Very much like etching concrete with muratic acid, you must be very careful. You need to use in well ventilated area, and you must bring the acidic cleaner to a neutral PH rather quickly using an alkaline based soap. Proper clothing and gloves (as glasses) should be considered.
I see where it can be valuable to Justin and professionals .. but tread lightly. A good paint cleaner, or polish will remove any wax or sealant with ease. Just like polishing, less is the best initial attack.
joe.p said:
That was a real question brought up on another forum,adding spell check. AG may also have one we just need to know if its in place.
I think this was brought up because of the search button function. if words and threads where mispelled it would make it harder to do a search. I may be wrong, but dont the threads and post go into archives ?
Tip: Type your response in WORD first.
AIO for me but I'm going to start using my "pink moose" to trip then just go to my LSP (unless using a sealant)
adding a spell check was a question brought up on another forum,. AG may also have one we just need to know if its in place.
I think using Spell check was brought up because of the search button function. if words and threads where mispelled it would make it harder to do a search. I may be wrong, but don't the threads and post go into archives ?
is this a little better
Words of wisdom!! Thank you Killer for putting it out there! :grouphug:
