What makes you prefer clay magic?
Welcome.
A word of caution on grit guards and buckets. Grit guards do not fit all buckets. Check forum for discussion of compatibility.
Pleasure to help!Thanks Kurt, good advice!
I have not used the 3M swirl remover. AG website indicates rotary use so I don't know about using a DA.Sorry to occupy space here with such basic questions. Upon reflection it seems like we could probably get from 6 pads to three..maybe manufacturers just found a way to make more money. There's so much overlap it makes me think yellow white red are the way to go. The in betweens may be for show car guys!
Anyway, I really value the opinions here, so much knowledge!
I use a red pad for sealant application but I use WG DGPS as my main sealant. I also separate my red pads into sealant vs waxes.Sorry one more clarification...
Orange pad for 3m
White for aio
Grey for sealant glaze
Red for wax
Don't remove anything with the machine, remove all products by hand (well break down the 3m then remove)
Are those the right pad choices? Since there's overlap, I'm not sure when to use white vs grey.
Sounds to me like I should be getting 2 red and 2 white and 2 grey for now, since I don't have a ton of correction..
Then use the white for Klasse AIO
grey for Klasse sealant
Red for wax application.
I guess I'll place my order, it would be really nice if it was here before the weekend. Where is AG located? Do they usually prep and ready an order within 24 hrs?
