addysdaddy
- Jun 13, 2012
- 980
Wanted to report back after my initial experience with the AF Spirit. First off, my paint was very clean but would not pass the plastic bag test. I nanoskined the entire car about two weeks prior so I didn't really want to do all that again but here in south Florida, 30 minutes after you clay a vehicle it needs to be decontaminated again. Hard to understand but that's a fact.
Anyway, the AF Spirit was without a question the easiest paste wax I've ever used during the application process. Used a P21s foam applicator and only did one 10/2 twist of the pad to coat the surface. Than applied that amount to half a panel and went back to the jar to reload with wax. So that's the good news.
The bad news is I waited 10 minutes and using two MF towels tried to buff off. It was like iron - had to use some detail spray to break the wax and even than it was a bear. On the next panel I tried applying using the same amount of product and only waited 5 minutes - same poor result. Finally on the roof, I did half a panel and then removed the wax immediately which yielded acceptable results. It wasn't Fuzion easy to remove but it was fine - you could still feel the towel breaking the wax and needed a "little passion" to remove all the residual wax. Whereas with Fuzion, there is absolutely no towel resistance whatsoever in the buffing process.
So obviously I'm completely dejected and believing I doing something wrong or is that what I should expect? The other bit of great news is that it looks fantastic on the Ibis White - very glossy & wet looking. Outstanding marks for the Spirit - so if I can just get the "process" down for this particular wax, it will clearly be my Go To LSP.
