Mike, is the Rupes Yellow DA foam pad or just the Rupes yellow foam?
RUPES has foam pads for dual action polishers and for rotary polishers. Stick with the pad for the tool you're using.
Also, if i decide not to go with vessel coat, do I just use the captains compound only or would it require the sealant wax?
Yes. The Captain's Compound, like the majority of compound on planet Earth are "dedicated" products, they are designed to abrade the surface. They do not include ingredients that provide protection. In fact, most are water soluble. This doesn not mean they are water-based, just water soluble. And this means any shine they create will wash away with water.
Also sorry last questions, will two of each pad be enough for the boat?
Probably. One thing about the new RUPES foam pads - they are STOUT. They will take a beating and keep on buffing. I have around 40 of the new yellow 180mm CP foam pads in the garage and we use the hell out of them. Then wash them in the washing machine and then dry them in the dryer and they just don't seem to wear.
Can i use the dr. Beasley on top of the captains for a sort of ceramic coating.
Yes. You'll want some of the stout towels I've been sharing for a few months now. The Dr. Beasley's products can be a tick sticky to wipe off and the right towel makes a huge difference. These towels will also work great for wiping off the Captain's Compound. I recommend getting enough to make a small DEDICATED wash load so you wash all the same things together.
See here and I'm talking about the orange towels. Link is in write-up.
2016 Mercedes-Benz S550 4MATIC Coupe - Wolfgang Paint Correction and Ceramic Coating
I also would to buy the towels you like to use so much in the videos.
Ha ha... I read the above sentence after answering the previous question. I'm thinking the orange towels are the towels you're referring to.
I am going with the Beast 3401 for the polisher since it seams that is the best tool for the job and safe for the cars.
Good choice. The best and most versatile tool on the market in my opinion. Because FLEX is discontinuing the original BEAST and replacing it with the new Supa BEAST - I'd recommend getting an extra backing plate or two for the BEAST.
Thanks again for your expertise.
Your welcome, just trying to pay it forward. Anytime someone comes to this forum for my help instead of the myriad of other options - well I appreciate it. :cheers:
I hope to get everything ordered in the next day or so. I will definitely take photos and post when I am done with the boat.
I am a total newb, do you have a line to call to make sure I am getting everything.
Near as I can tell, Andre is the only customer support employee that gets on the forum? At least when he's on his name shows up on the "Who's Online" list of members on the left hand side of the forum homepage.
Andre also helps me to teach both the boat class and the car classes so he's VERY KNOWLEDGEABLE about all the stuff in my head I dump out in the classes. I'd call customer care and try to get through to Andre. He's also a super nice guy.
1-800-869-3011 x1244
