What is this on the paint?
ExoticAutoDetai
They look like half circles a bunch of them together in different spots. They were hard to notice until i looked closely. They kinda look like this )( ( )
Anybody know what is it? I know is not orange peel i thought it was but is not. It doesnt have a texture either.
Looks like either bird crap etching or clear coat that's starting to crack to me.
Might be bird poop etching. It is hard to tell by the picture.
Is it on one of your vehicles? Looks like sanding marks left from a DA sander. Can you catch a finger nail on them? Looks like the could be removed by wet sanding and compounding. Would test the thickness first though, or be very carefully if you don't know the history of the paint.
Looks like DA sanding marks (pigtails) to me. More than likely, the painter sanded an area and a piece of debris forced under the pad, causing the unique (((( pattern.
Or, it could be a form of checking.
Is that Japanese paint? If so, the clear coat can be soft and can have dents (not so much scratches) instilled in it from debris getting trapped under a buffer pad, MF, applicator, or just in general from daily use. Happened on my Subaru STi and they are hard to remove with out removing a good bit of clear coat. If it is a Japanese car I would try compounding first and if that reduces the marks pretty good, I would live with it unless you feel confident wet sanding and know how much paint you have to work with.
That's what I thought they were as well.
Prob clear coat failure or bird etching. When this happens do you just tell the customer there nothing can be done unless you want to repaint it?
Well this is a Dodge Red Hood i picked up from the junk yard to practice on.
I dont feel it with my finger nail so therefore i am pretty sure i can remove them.
If is clear coat failure or pigtails it can be removed right?
my plan is to clay it, color sand 1K first then even it out with a 1500
Polish it out then sealant then wax
Clear coat failure..... no cannot remove..... well, guess you could remove lol - but would not be worth it :bolt:
im confuse why is not worth it?
Clear coat failure = clear coat failure lol! If you see clearcoat failure (which this is probably not) you will just want to get it repainted. There is no procedure that will be able to remove the surrounding clear without removing or damaging the paint underneath..... If I am wrong anyone, please let me know!
If it starting to show clear coat failure, I wouldn't remove what ever is left. Unless you know what your doing.
Can you guys just sand it down and then apply a clear coat from those pens at auto stores, then just sand it down?
Pretty sure that's not crows feet. Crows feet is splintering of the paint. That looks like etchings in the clear to me.
I would try wet sanding...I really think you can level those out. I honestly think it's just etchings from someone sanding.
I'm pretty sure you can even it out, but by doing this you can remove some if not all clear coat.
Im going go head with my game plan then I trust my instincts lol
It's a test panel anyways! Have at it!
I would just take some 2000 grit, wet sand, compound, polish.
Worst thing that can happen...is that you burn the paint, or break through the clear. But, it would be a learning experience regardless.
I am going to start really less aggressive I will post pictures when I am done. I am still waiting on my friends pictures he took today with his Sony camera his camera is better than mine
