What order do you apply gyeon wet coat and tire and trim products?
SWETM
As the title say what order do you apply gyeon wet coat and carpro perl or simualar products?
If the weather alows I will do a decon wash tomorrow and apply wet coat as lsp. I have a sio2 car schampo also that I think to test out. Will it be to much for the sio2 schampo and wet coat you think?
And would you do the tires and trim before you apply gyeon wet coat or after. When I have used wet coat before I got the both the tires and trim nice and beading. So I'm not certain how carpro perl will do after I have applyied WC. And if perl applyied before and dried will hold up to WC and the pressure wash. My gutt say to do perl first then WC.
How would you do with it?
Tony
I don't know which SiO2 shampoo you have but I would choose either the shampoo or wet coat instead of using both.
With regards to the trim and tires, you could avoid spraying those areas. You may get some slight overspray but I am sure you can control that with a slight tweak to your technique. Then you can apply perl to the trim and tires without some of it being washed off the surface.
Thanks.
I will test to not get wet coat on the trim and tires. And apply perl last to it. Will use wet coat only since I have used it before. The car schampo is Angelwax Enigma and have not used it yet and it's a friends car so not the time to experiment on that.
