what order do you use?
ntwillie1
Hey all.
In reading through many threads I often see that some people use the following process:
Option A
1. Wash
2. Clay
3. Iron-X
4. and so forth
and other people use:
Option B
1. Wash
2. Iron-X
3. Clay
4. and so forth
So my question is this, what should come after the wash, paint decontamination using a product like iron-x first or paint decon using clay first. I personally go with Option A. Thanks for chiming in.
It would make more sense to use iron x before claying to get all the iron deposits off the paint before you clay. Helps make claying easier and faster while also being safer.
Adding on to this would you recommending wash, dry, then iron x or wash, iron x, then rinse then dry?
I wash, rinse, iron x, then rinse. I usually don't dry after the last rinse because I usually go straight into claying after iron x.
This is what I do also. As well as Trix on lower panels if tar is present. :xyxthumbs:
Thanks for all the responses. Looks like everyone has been going w iron-x first. I will try that on my next detail.
Subscribe
Sent from my SCH-I535 using AG Online
I subscribe to Option B. With option B the more expensive product (IronX compared to Clay) does the most work. As for washing or rinsing with either option you wouldn't need to if you were going to polish. That said, it doesn't hurt to be extremely clean and disciplined.
Mwoolfso - are you saying that iron-x has the ability to remove above surface contaminants and after doing iron-x and a Baggie test that the paint should feel smoother? My understanding was that iron-x was used to remove the iron particles and contaminants that clay can't which is why I was using clay first and then iron-x. If. Am wrong I would like to know because I want to make sure I am using my products to their best ability and in the correct order. Thank you everyone for your input. Keep it coming.
Great post. Just got ironx today and have never used it before. Would the order that you have recommended change if the car already has a fairly fresh layer of sealant to begin with? I guess my question is can ironx do its job or would the sealant prevent it?
Seems I may have killed this thread but I'm still asking. Can ironx penetrate through a sealant? Specifically near fresh WG 3.0? If not, wouldn't you want to clay and polish prior to ironx?
Its possible that iron x may remove some of the sealant. It wont do its job unless there is iron particles that need to be removed.
Sent from my SAMSUNG-SGH-I777 using AG Online
Mwoolfso - are you saying that iron-x has the ability to remove above surface contaminants and after doing iron-x and a Baggie test that the paint should feel smoother? Yes. That has been my experience. That is why I IronX first, before Claying.
My understanding was that iron-x was used to remove the iron particles and contaminants that clay can't which is why I was using clay first and then iron-x. If. Am wrong I would like to know because I want to make sure I am using my products to their best ability and in the correct order. Thank you everyone for your input. Keep it coming. You are not "wrong" with your process. It's OK to clay first, then IronX. As I said before I'd rather the more expensive product do most of the work (if at all possible)
