nissenc1337
- Dec 21, 2012
- 250
I've seen a lot of people use 4" pads when applying wax to their cars after they completed their correction. Is there a reason for this or does it really not matter?
Yeah, basically whatever works for you. The bigger the pad, the less work you need to do. Of course, a huge pad won't fit in tight spots, so there is a balance. But, to really answer your question, it makes no difference if you use a small pad or a large one. It's all about the job and the result when you're done.
