What "paint cleanser" would work best with Menzerna Polish & Collinite 915 LSP?
mdgrwl
I'm looking for a good cleaner that will work with my collection to get off contamination in between corrections.
I use Collinite 915 as a LSP, and Menzerna FG400 / PF2500 / SF4000 for correction. I need something when I don't need a full correction to clean.
I'm stuck between P21S Paintwork Cleanser & Pinnacle Cleansing Lotion since they seam to be more geared towards nuba's.
Any tips?
It looks to me that you would just be using the "paint cleaners"
you've mentioned, for "cleaning" the applied Collinite #915.
And by "cleaning" the #915 I mean the very real possibility
of removing some, if not all of it... by using the "paint cleaners".
IMO:
Using a rinse-less, or waterless wash products, or even detail sprays,
would suffice for "in-between cleanings".
Its a DD and sometime there is contamination that a wash and QD wont get off the paint. Just spots here and there...
Wondering what chemical cleaner to use... probably over thinking this, but still would love input.
I'm guessing your looking for a paint cleaner to clean off LSP and start with a fresh slate - not a wash product to clean your paint ???
Anyway, two I recommend are based on what you are looking for. Prima Amigo is mind numbingly easy to use, has very light abrasives, and leaves a glazed slick surface behind. Poor Boys Pro Polish is also great and leaves behind no glaze and has no abrasives.
I've only used these by machine, but they can be used by hand.
