What PH neutral soap is everyone using these days?
How is 3D Pink?
Good soap. I prefer the nano pails as i wash alot of stuff. And i know you wash your vehicle alot lol.
Half oz is all ya need for a 5gal bucket wash or full foam cannon
Did a quick wash to see how well Hyperwash performed.
It's ok.....nothing to write home about...don't like the fact it is so thick, it was hard to measure out 2 ounces for foam cannon.
It pours in globs
Adams mega foam is easier to use and creates more foam....my $0.02
SSKkyrK.mp4
https://i.imgur.com/SSKkyrK.mp4
It pours in globs
SSKkyrK.mp4
I am coming to the conclusion that along with simple differences in individual opinion, observations, etc, I think a huge part of this equation comes down to water chemistry
I have used Gold Class for close to 2 decades and in Alaska I never had any reason to complain as long as I used it within its limitations
In Hawaii, not so much, it sucked for anything beyond the lightest dust that ONR would have laughed at
Same product, same process, same nut behind the wheel…
It has to come down to water chemistry, and not just hardness
Alaska was straight untreated well water from a private well that was HARD
Hawaii was a private community water system that was pumped, filtered, treated, etc to the same county standards as the municipal system
The water there was HARD as well
Gold class sucked there and treated vs non treated water was to me the only difference
No, I did not get it chemically tested so yeah there could have been other factors
I’m just thinking out loud and trying to partially explain how we as a group can get so much variation in our results with the same product
I'm sure any negatives in this product on my end is 100% the fault of my water chemistry.
I have hard well water...REAL hard!!
I'm just curious how Adams MEGA foam can be so thick with foam when the soap is as thin as water.....crazy!!
FWIW...I have a 1/2 of gallon of GC leftover from my 2011 Silverado....not bad soap...but never rinsed clean up here and that truck was white.
I used it once on my black truck.....HA!!!....forget it!
Enjoying my first bottle of reset, but still prefer my made in the USA 3D nano pails
You can foam Hyper Wash but it's not marketed as a foam cannon soap. Adams mega foam is formulated for using in a foam cannon, etc. Blackfire foam booster could help. Haven't personally used that.
He was very very hard to watch and listen to, so condescending, then he pulled the stunt with the middle european bombshell and any credibility he had went right out the window
In my mind anyway
I lost interest when he was always going on about how his “industry is ripping us off”.
Then he comes out with his on products and every is same prices or more of the products ripping us off…
I brought that up along time ago in one of these threads.
Eldorado did not like Optimum Car Wash at all because it woudn’t foam and for me it was one of the foamiest soaps I’ve used. I know what I sw and I trust Eldo’s reviews…. Had to be our water.
OCW does foam well but I prefer soap slickness and that was just decent. Not Mystic Bubble/Reset slick…
It pours in globs
Foam is over rated any way. Its not like its actually *cleaning* your vehicle if its thicker. I foam just for some extra lubrication. That's all.
I get plenty of thick foam with 2 oz in my wide mouth Harbor Freight foam cannon (w/1.1mm orifice).
But I will agree about the viscous nature of Hyperwash. A little annoying to measure out at times. Hardly a deal breaker.
Used Meguiars Ultimate Snow Foam 1:5 in my 3D Foam cannon to wash the black MDX as sun was setting yesterday. Let it dwell for about 2 mins then used mitt then rinsed, and noticed I got severe streaking. It was relatively cool but noticed it was drying pretty quick which I assume was causing the streaking.
This morning I used the soap again at a 1:10 ratio and still got streaks on the silver sienna. Maybe not as noticeable but glass showed the streaking. Used same method, but this time finished up with a mitt and GG Brilliant Finish, then Formula 4 spray wax. I’m not so sure I will give it another try.
Heres some PH neutral for ya...3D super pre soak
Late to the party, but I've learned quite a bit here.
Does anyone apply hyperwash with a pump type foaming sprayer? If so, any ratios to recommend?
Lol… definitely not neutral… how you like it?
Oops good catch my miatake, it is ph balanced...it sits on the scale at ph8.
And i like it. Been using it for almost a year if i remember correctly. Im almost getting down to near the bottom of a nano pail and will be ordering another. Cleans well, highly concentrated
Ph of 8? Nice level if it cleans well. 3D website would have you believe it’s high alkaline.
3D:
“This is a high pH, strong degreasing pre-soak that you used to super clean the exterior of a vehicle before using a normal car wash soap.”
3D:
Yeah i know, i dont care for that discription. In my eyes its a bit deceptive. Had to look at the sds to find the ph level.
But it does its job
