emmjay
Member
- Feb 2, 2015
- 848
- Thread starter
- #21
IMO on soft paint it is usually the drying towel that causes the problems.
I use a grout sponge when I do a 2 bucket wash since I like the way it releases any dirt when squeezed into the rinse bucket. On a really dirty black car with soft paint I will not wash the whole door. Instead for instance I will wash the top 1/2 of the door then rinse the panel. Then after rinsing the sponge I will wash the bottom section and rinse the panel. I am just trying to make sure debris gets rinsed off and I am not pushing debris into the panel from the top to the bottom. Thinking about it I guess I could start the wash on the bottom of the panel to prevent this.
Anyways I still think drying is still the major cause of marring in soft paint. Maybe to test you can wash and dry one door as normal and then just wash and blow dry the other door but do not touch it with a drying towel and see what the results are.
Drying microfibers are better used when damp. Running a dry towel across a surface increases the chances of marring esp on soft paint. Using a drying aid like Meguiars Ultimate Detailer or Ammo Hydrate help the drying process and provide a bit of a buffer. In addition you can use the towel and blot and not drag it. There are also great drying towels like Carpros Dry Me Crazy and Mother's PFA drying towel that help a lot. The best bet is to not touch the paint though maybe wash, blow dry, then blot the drops that are left using a drying aid for assistance.
This is my first car with soft paint, definitely a pain and i'm learning a lot while at the same time it is testing my patience haha.
I will try the drying aid, and avoid the dry waffle from now on
