What Sealant would you choose??
How will you choose, from all these personal preference suggestions? :dunno:
You know you want to try the Prima Hydro Sealant. :coolgleam:
Well you already own one of the 2 best sealant out there.. 3rd is Wolfgang DGPS IMO, so you're limited on choices. But I would recommend Opti-seal, the result is amazing and application is the EASIEST out there, just like using QD...
I figured with the sealants look similiar, might as well go with the one that can give different sensation in application..
Happy detailing
I just got my order with DP Poli-coat, but haven't got to use it yet. Waiting for the new truck to get in.
Save yourself some bucks and use what's left of your BFWD. I highly doubt any other sealant you haven't used will look as good or be as easy to apply as BFWD.
:iagree:Stick to what you know,if its been working for you.Theres nothing worse than trying something new and not at least getting the kind of shine you're used to.IMO when the car has been prepped good and you use a good wax,theres only subtle differences and personal preferences that sway you to one wax over another:buffing:
Four Star UPP, Opti Seal, Duragloss (501, 111, 105), Supernatural Hybrid
UPGP or Opti-Seal they both are the easiest to apply and give the same results.
I would just stick with PL. It's an amazing sealant! If you really want to try something new, then I would suggest Wolfgang DGPS 3.0!
The best I've used so far as been the Menzerna Power Lock sealant ( I have not used BFWD yet). The powerlock slickness seems to lessen within a few weeks but the protection and wet-look gloss is still strong. It's by far a better looking sealant then wolfgang dpgs 3.0!
Ultima UPGP is great and looks very wet and glossy also, most people will not be able to notice between PL and UPGP. The benefit of UPGP is its Wipe On Walk Away =)
Side note: My wheels were filthy and had tons of tar/grime spots that would not budge! I used PS21 wheel gel to wash, then hit the wheels with tar remover and a bug sponge. I had to repeat the tar remover/sponge step multiple times to remove most of the tar spots. Some still remained =/. I then cleaned and sealed the wheels with Klasse AIO and added a coat of the Ultima UPGP. I am concerned with the durability of UPGP and AIO, however the wheels look great and the UPGP adds nice slickness.
You think it's better than WGDGPS? I would think it's close to the same thing since Wolfgang uses Menzerna to make their products! I've also heard that BFWD is close to Power Lock as well!
