By the way, I know of approximately (I am not counting them) only 6 cases of that "rash". Therefore it is gross misrepresentation to say "like so many others".MY Flex, like so many others has the backing plate rash ...
Obviously AG's excellent customer service is already helping you with it
So, just to satisfy my curiosity and increase the knowledge, did "rash" develop because bolt was not tightened prior to use and Flex was used with much pressure / offset pressure?
No, I am not going to hate youYou're going to hate me, because I know you've been drawing out this conclusion but no, it wasn't because of the hex nut holding the BP to the flex.
Maybe, and I can not speak in their name to be able to say any pro/con to that, or even venture to guess whethere there is a good reason and whether we are misunderstanding the tool.To the point, it MAY have been due to angled pressure, but I also thing that should've been accounted for in designing the FELT or whatever protective gasket-like product is between the BP and what not.
You are welcome. One more question, please: Have you put double washer under the bolt's head? When I did that it was very hard to get things to touch even with offset pressure. If you did not can you do me a favor please and use double-washer with next bp?... and ZoranC, I know you've been the watchdog for this sort of thing, so if it wasn't for you, this might've happend a lot sooner, thanks for the headsup on tightening it, it got me through at least one major paid job!![]()
You are touching on several subjects there:Zoran, you think too long of an extension cord or not a thick enough gauge extension cord would be an issue? That metal housing gets HOT!
IIRC, I know someone has super-glued the felt just to make sure it doesn't drop out.
Hey Meghan, thanks for your help, I just spoke with Dwyane.
In future, for anyone else who may have this issue, here's the number to call:
It's Powerhouse distributing, and they care of all the flex warranties.
1-888-809-4749,
Very friendly, and I'm glad AG deals with them. What ended up happening for me is that they're sending me a new BP and felt ring and the trick is to apply white oil (or some good lubricating oil) to that felt ring and have it saturated. That should provide enough lubrication to prevent heat build-up.
I see now what you meanWhen I say angled pressure, it was more of an accidental thing and to illustrate my point it's like going over a panel that's more organic than flat and the pad starts to jump and move around like crazy. While trying to get it under control that's when I applied the angled pressure.
I always tried to stay perpendicular, but anyways, you mentioned a double washer, my flex only has a single washer.
You put another washer underneath the bolt's head.
Just a side comment (to make you think, not to "comment" on anyone):
How many of us would dare to pressure down under angle rotary at full speed? Probably not many.
Flex has power of the rotary. Don't use Flex the way you wouldn't use rotary.
