What was your first detailing mistake/error?
Forgot to use 3m automotive tape to tape off the car, while using my flex 3401 using Meguiars 105, 205, on a black car. Big mistake. FYI, Automotive tape should be included, in the packages DA combo packages.
Once I used a normal tape, instead of the blue scotch or the 233+........
Big big mistake also..... 3+ hours on the detailing removing all the residue it left.
First attempt to get a bad scratch out. (go big or go home) Started with a rotary, wool pad and some heavy duty compound. Didnt like the results, went straight for the wet sand with 2000 grit. Scratch was gone, was happy, now its time to get out the wet sanding marks. End result, not enough clear coat. Glad it was my car, found AG after that and smacked myself a bunch.
Wow you really went big
Sent from my SGH-T999 using Tapatalk 2
