What's going on in this picture?
raheelc
Hi Mike,
I hope you're doing well. I was recently taking a look under the hood of my 2010 range rover sport and noticed something unusual with the paint on the driver's side fender which isn't present on the passenger side. Was wondering if I could get your input as to what may be happening (or anyone else's opinions/expertise).
There are numerous lines running in the paint, its kind of hard to explain, the pictures will give a clearer idea of what's going on. These lines don't extend down onto the exterior paint of the fender, they abruptly stop at the curve of the fender, where it begins to slope downward. Here are some pics:
This is not present on the other side, and its not fragile/brittle/chipping off anywhere.
Thanks!
Sent from my SM-G930T using Tapatalk
I actually have this on my back bumper and assumed it was from a minor incident(backing into something at very low speed), but would like to see what other, more experienced, people have to say
only other thing I can think of is heat/over exposure to light/UV rays because before I got my car it sat everyday with the back end getting direct sunlight for ~10years
Thanks for the response. As far as being from a minor incident, I don't think it has been in an accident, as the vehicle has a clean record, and is also a Certified Pre-owned vehicle from Land Rover (Pretty sure any vehicle that has been in an accident is automatically ineligible for CPO status. I could be wrong on this point though, and dealers are obviously known for shady practices sometimes).
Also, for the heat/UV light, not sure if that could have been the reason because when the hood is closed this part of the vehicle is covered by the hood, so it doesn't receive any direct light/sun. The vehicle is parked outdoors everyday though.
This is clearcoated cracking. The only option is repaint. The panel must have been repainted at some point. You can look it up on Google under paint defects cracking( sorry don't know how to link).
The fender must have been repainted at some point. I was a Land Rover tech for 10 years and have never seen factory paint do this.
As far as the CPO inspection, the dealer only has Carfax to reference if the accident wasn't reported they have no way of knowing. The only way to know for sure would be with a paint depth guage.
Definitely cracks. That part of the fender has been repainted - factory paint doesn't do that. In the close-up pic it looks like you can actually see a tape line where the repaint was done. Looks like only the jamb portion of the fender was repainted. There's only one way to fix it and that is to strip the cracked finish and repaint it.
•Looks like what I've heard called, over
the years, by these various names:
-Cracking; Checking; Crazing; Crow's Feet.
•The "Fix"?:
-Needs properly prepped;
and then re-sprayed.
Those inner fenders are dry misted clearcoat.That was a definite repaint.
•The "Fix"?:
Love the hi temp great stuff.
As stated, it has been repainted at some point. A respray is the only fix. Since it is only on the top and covered by the hood when closed I would recommend just letting it be unless it really bothers you or starts to flake off.
Thanks for the input everyone. Glad to know what's actually going on. Yeah, I'll be leaving it alone for now since its only under the hood, and as long as it doesn't start to flake.
Any suggestions on how to prevent/delay it from flaking?
