paint prep is stronger and is for removing waxes and sealants. Also needs to be rinsed off with water
pre wax is for removing residual polishing oils (from compounding and polishing) before lsp application. It can just be sprayed on and wiped off. No rinsing required.
Paint Prep is used to remove preivously applied LSPs. Pre Wax cleaner is used to remove polishing oils/residue so that the paint surface is honest/true and ready for an LSP.
