Spray...how is any errant-mist controlled?
the same way it is dispensed...the trigger
Wait 5 seconds...OK....
i would've said longer but dwell time isn't necessary with wb
Then agitate...for how long?
as long as it takes to scrub all of the "dirty" areas of the wheel Before:
Rinsing-off...To what location(s) does this effluent rinse-off?
the ground, driveway, and eventually a storm drain...unless you have a filtration system in your garage to capture and purify the water/wb run off and pay for a company to come and pick up contaminated water the chemicals will end up on the ground at some point
Why no mention of PPE...?...
PPE and warnings are on the product label
Or braking system's components being "touched" by this product?...usually when wheels are this bad i remove them from the vehicle for cleaning
