Wheel-well brush/tool help?
Crist Clapper
The traditional wheel-well brush will not fit between the tire and wheel-well. Suggestions for an alternate brush or tool to the below?
I tried this one... Although it fit... The end was too pointed.
Anyone try the below Wheel-woolies? Dimensions of the handle?
Although the wheel Woolies would fit, I don't think it is an appropriate use of the tool. Try cutting the strands down on the green one.
For wheel wells with a small clearance space, I use these brushes.
Actually, I use them for all wheel wells, they work great. And best of all they only cost 99 cents so I always have spares just in case they end up trashed. It's a simple dishwashing brush. This perticular 1 is for my carpet art.
I find the Speedmaster wheel brush to work great, not sure why you had a problem with it, you can flex the end to whatever shape you want. If you're having issues that bad maybe you need to jack up the car.
