Wheel Wells
hondajake
What do you use to clean wheel wells and inside of mud flaps?
I recently tried dp exterior cleanse all dilutes 1:1 with a stiff bristled brush and i liked it.
## Grime Reaper or an APC like Meguiars and a couple of brushes.
Amazing Roll Off at the same time as using it on the tires.
thanks guys for all the help!
I will look into each of these.
Apc like Purple Power and a stiff brush should do the trick! Degreasers work too!
I use a heavy degreaser product called Purple Power..cut through any grease or containiment within seconds, then wipe with a wheel mitt
Does AGO sell simple green? I've used this product before, but never on my second LOVE........ Does it work better than ARO?
I have some simple green and I was just asking since its a degreaser. What is ARO?
I use Simple Green dilluted like 6-8:1 and a long handled Mothers brush and I've never had to spend more than a few good swipes to get wells clean.
This is easy. Just use wheel cleaner, let it sit for 30 seconds, and then rinse off. If it's stubborn dirt in your wheel wells then agitate with a wheel brush after spraying with the wheel cleaner.
Auto Geek sells wheel well brushes on their site; one of them is from Mothers.
