Which DoDo?
lkotsios
ON red which DoDo will have superior looks Banana or Orange?
very simply, the softer wax, Orange Crush, is easier to spread with fingers directly on the paint, but a little too soft for foam applicators. so a harder version was made for warm coloured cars, Banana Armour, so not to overload the pad.
personally, i would say go with a couple of layers of Orange Crush - killer finish 8)
I have only used orange crush but the look was fantastic. Let's be honest though - you will purchase orange crush, be enamored by the result, but then start to think "what if?". You will then proceed to AG and purchase the banana armor as well. :P
Try the mini size first.I did that with the Diamond white hard and Light fantastic soft.Put the soft over the hard.I prefered the soft myself.Those 30ml jars will cover the entire car at least twice.Will probably get the full size soft and skip the hard.
The research I have done - go with Crush! Couple of layers!
Also, they said you really do not have to lay the hard down then the soft...
I have a red car... Banana Armour cannot be beat ! I've even tried the Banana/Orange combo.... did not hold up well. The Banana lasts and has a shine that is fantastic ! I also use the Tropical Mist between waxings.
I used orange on my red Subaru... didn't really notice much more pop, will probably be trying banana soon.
If you want an excellent general color DODO then try Rubbishboys juiced edition or Rainforest rub they are both excellent on any color. Also Austintacious kicks butt as well.
