If the Ryobi hose is the same as the GreenWorks one, then it's the same as the AR390SS hose and not much more user-friendly than the hard plastic hoses. More flexible but with memory problems. It always loops on itself and snags under tires etc.
Dont you hate that!!!
I'd get a Flexzilla, but... damned proprietary connectors. The GreenWorks' hose appears to use standard M22s at each end, same as the Flexzilla.
Is Flexzilla hose rated to handle water under this type of pressure for very long? The normal hard stiff hoses are like that for a reason you know.
Thats why its called a flexzilla pressure washer hose....not garden hose.
Got this from Home Depot I have a gas unit but I wanted something electric and not to expense. At $109 I hope it will fill the bill, it is rated at 1600 psi and 1.2 gpm I'm sure those numbers are inflated. It's small and easy to move as far as power it's ok only problem is having a real pressure washer, it is fairly quiet which is one of the reasons I wanted it. I was more surprised in how well the foam cannon worked, gas unit is still the way to go for that but then again I'm not comparing apples to apples. What I do have to use to is the fact it sounds like it's seizing when it kicks in, again it's electric. One draw back is the hose length and a pretty cheap gun, but it really is a cheaper unit but if it holds up for a few years I think it will work for the money and hopefully the neighbors will like the quiet operations early in the mornings.
I just got the same one and for some reason my MTM foam cannon WILL NOT fit into the quick connect fitting. I tried it on two separate Ryobi wands and both of them would not accept the standard quick connect fitting on the foam cannon.
