Rasky is the LTT as good or better then LM?
Look forward to reading your thoughts on it. Also LM's STRONG is in a foam can but it's listed under there Suede and Alcantara cleaner. Wish I would have known/read that I wouldn't have bought both.
From the article
“While vinyl-coated leather is care free by virtue of its protective plastic surface, it is also inaccessible for purposes of maintenance.” Meaning, of course, there is absolutely no point to using leather conditioners on plastic coated leather."
The water drop test tends to make sense. If you put a drop of water on a solid leather seat that isn't perferated or not on the seams and it doesn't soak in, it would stand to reason that a leather conditioner isn't going to soak in either.
If that's the case, then it would seem reasonable to think a vinyl/plastic treatment would do more good than a leather treatment if your seats are plastic coated.
