Which one first: Collinite #476 or #845
Whitethunder46
For my winter prep, I'm going to use both Collinite 476 and 845.
Which one do you suppose I should use first, or as the base wax and then top it with the other.
I'm leaning towards 845 as the base and then 476 as a top coat since it is a paste wax.
845 and then 476 ... for the same reasoning as you ... Or maybe get a little experimental and do, 845, 476, 845? Or 845, 476, 845, 476 ...
When I talked to Mike Taylor from Collinite he said to do the paste first and then the 845 for a deep wet look.
For maximum durability just do 2 coats of 476S about 1 hour apart.
