This is from Poorboy's site...
"Poorboy’s World White Diamond Show Glaze for Light Vehicles is an easy to use product.Spread it with a soft, clean foam applicator,(if applying by machine, set your polisher to a low speed) and work until a shine begins to appear. Allow it to dry to a haze and then buff off with a clean, soft microfiber towel like our DMT or Mega-Plush towel."
Since it states to apply by machine on low speed, I wouldn't think you would be doing any paint removal. My guess would be to use a mild pad like the LC gray pad or milder.
But I have never personnally used it. Maybe others with experience will chime in.
White Diamond is not meant to cut and correct, it is meant to fill and conceal. I'd use a Lake Country Hydro-Tech Crimson Pad. But then again I'd polish out the swirls and not use a filler glaze. I'd venture to say if you have the time to use a filler Glaze with a PC you have time to do a mild correction and be done with it.:buffing:
But on the other hand, this product might be the perfect thing for someone's car that has thin clear coat and doesn't want to do anymore paint removal. :dunno:
