fruitycups
- Jul 23, 2013
- 2
Hello Everybody!!
I recently came across two long scratches on my car. While they aren't super visible, if you know where the scratch is, the eyes can easily pick it up. Also in sunlight, it seems as though the scratches are black lines instead of clear so I am hoping it didn't cut through my clear coat
Anyways, so my question is, which products do I have to use to get these scratches out (its a 2013 328i in silver if it matters)? I read countless threads but the methods and options are just overwhelming. I did eliminate Turtle Wax compound because they said its a bit overkill for my needs.
So right now, Im stuck between, scratch X, swirl X, and Ultimate compound. A friend said to use ultimate compound+ultimate polish but I don't want to use something stronger than needed.
Again, there are so many areas Im confused in. For example, once I use scratch x/swirl x/ or UC, do I wipe away the excess with water and soap or just I just wipe it with a microfiber? Wouldn't that technically be smearing it more and not wiping it off?
Im also paranoid that using those polishing products will leave the area duller than the rest of the car. Im also confused on whether or not I can just stop at one product or if I need a wax/polish after doing step one (I was hoping there was one does it all type product.)
Thank you in advance!
Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
