which QD???
Instructions
Ultima Waterless Wash Plus+ Spray, Wipe Walk Away Car Wash Instructions:
Always work in a shaded area on a surface that is cool to the touch. Make sure surface is not gritty with dirt or sand to avoid scratching.
Ultima Waterless Wash Plus+ Concentrate is easy to mix, simply open the flip-top cap and squeeze container until holding chamber reaches ½ fluid ounce line.
Pour contents into Ultima Waterless Wash Plus+ mixing spray bottle. Fill mixing bottle with water and shake well.
Starting on the upper surfaces first, mist the surface to be cleaned.
Fold a clean, dry Ultima AutoSpa Microfiber Buffing Towel into quarters and gently wipe using a back and forth motion.
As the Ultima AutoSpa Microfiber Buffing Towel becomes saturated or dirty fold to a clean dry side and replace with a fresh towel as needed.
NOTE: Ultima Waterless Wash Plus+ also works great as a detail clay lubricant and a quick detail spray!
BobbyG here are the instructions from their website which you have probably already seen. They are the same as in the store ad. The QD ratio seems to be the same as WW, 1/2 oz to 22oz water which seems a bit strong compared to 1oz to three gallons of water for a RW. Unless they are replacing product for water for lubricity since there is no flushing effect.
My car sees the same conditions as yours. I only use a QD for a drying aid. For the wipe downs I use DP Waterless or CG's equivalent. I just prefer the extra protection a waterless wash gives. Plus I can keep this in the trunk and do it at the storage area the car is kept at.
hmmmm never concidered the DP. Choises, choises, what to do???
