White Paint Needs Love, Too. - 2014 Porsche Carrera 4S - Paint Correction - CQuartz Finest - Attention to Detailing Peoria
zmcgovern45
The owner of this vehicle contacted me because he had been referred by a coworker and was interested in having his paint corrected and protected for his newly acquired, beautiful Porsche. We opted for a 2 step correction to remove the majority of moderate to light defects, though some scratches were too deep to safely remove. This process really brightened up the paint and increased the gloss and clarity in the paint. 2 coats of protection were then applied and baked for even richer gloss and years of durable protection and easy maintenance. This is one gorgeous car!
Process
Tires: Tuf Shine Tire Cleaner & Tire Brush
Wheels: P21S Gel Wheel Cleaner & Various Brushes
Foam Soak: Citrus Wash via DI Foam Lance
Wash: Citrus Wash
Chemical Decontamination: CarPro Iron X & Stoner Tarminator
Wash: Citrus Wash
Mechanical Decontamination: Nanoskin Speedy Prep Towel, Clay, Nanoskin Glide as Lubrication
Wash: ONR
Dry: DI Waffle Weave Towels & Master Blaster
Paint Thickness Readings: Defelsko Combo Gauge
Inspection: DIY LED work lights, Coast HP7, Brinkmann Dual Xenon
Tape off trim and delicate areas: CarPro Tape (<- the best tape!)
Paint Correction: Griot's Fast Correcting Creme on MF Pads via G21 & Rupes LHR75e
Polishing: M205 on Yellow Rupes Pads via G21 & Rupes LHR75e
Surface Prep: CarPro Eraser & Microfiber Madness Crazy Pile
Paint Protection: CarPro CQuartz Finest (2 coats)
Wheel Protection: CarPro HydrO2
Tire Dressing: CarPro PERL (neat)
Exhaust: CG Metal Polish via MF towel
Glass: Meguair's D120
The vehicle was dropped off with a heavy layer of dirt, grime, and bug guts.
As with all performance vehicles, the wheels were exceptionally dirty.
As always, I began by thoroughly cleaning the tires and wheels
The wheels revealed a bright silver finish once cleaned.
The wheels were sealed for easier cleaning
I then turned my attention to the paint. The vehicle was soaked with a strong shampoo to help loosen surface contaminates before washing. The vehicle then underwent a multi-step process of washing & decontamination
IronX was used to remove bonded iron particles from the paint prior to claying.
IronX is a clear liquid that turns purple as it reacts iwth iron particles and begins to dissolve them.
Once the paint was completely clean, the vehicle was brought inside for thorough inspection. It is clear that the paint needed a fair amount of work as there were swirl marks, scratches, and holograms that needed to be removed to reveal the true beauty of this bright white paint.
After a series of test spots were performed, I was able to determine the best plan of attack to remove the majority of the defects from the paint in order to produce a clearer, glossier finish. Here are a selection of before and after photos from the compounding process.
The vehicle was then polished further enhance the gloss
Exhaust Tips Before & After Polishing
The tires were dressed in a premium water based dressing which contrasted nicely against the white paint
The vehicle was then coated in 2 coats of CQuartz Finest ceramic paint coating. The coating was then baked with an infrared curing lamp to increase hardness and gloss.
The vehicle looked great after all the hard work!
I tried my best to capture some of the gloss, but it is quite difficult for me with white paint. The car looked amazing. Truly one of my favorite vehicles.
Great work as usual Zach. Really nice pictures also. I would never be able to get pics of swirls on white or silver.
another stellar job zach :props:
p.s. how you liking the G21?
Wow fantastic. That's my favorite color!
How much hp did you add when you took the swirls out? Like 75? :)
Great work man! Crazy how much damage was on that car already.
Wow, you did a amazing job on that sweet ride buddy:)
