I have a hard enough time just keeping my car clean.....let alone worry about the valve stem location
lol I thought it was normal. I have even lined up white letter tires with the stems on muscle cars.LOL, I'm pretty particular about a lot of things, but haven't ever thought about this one! Now I've got something else to think about!
Exactly. Those are easy once you figure them out. I got to a point where I could slap them on without thinking about it.The engineers at GM does that for me. The 2007-08 Silverado LTZ wheel caps have a recess for only one of the six lugs. You have to line the dimple to the lug 180 degrees from the valve stem or the cap will not seat properly.
It was a bit frustrating until I saw that recess. :doh:
Yup, it's the OCD.
When I work on electrical outlets and switchboxes, all the screws are lined up either horizontal or vertical, was taught that way from an old timer, now I'm that old timer!
Detailed my 'grandsons' car and wheels, popped off the center caps and lined them up with the valve stem.
I'm more concerned about correct torque.What about lining up all of the screws on the car to be perfectly horizontal and vertical?
Think about taking it to the next level. Make a screw tight, and see how far it goes past straight vertical and horizontal, and then unscrew it, being careful to be aware of the exact point at which the screw disengages the threads, and then rotate the screw as close as possible to the amount to which it is out of alignment when tight, and then engage the threads at that point and re screw it in, for the most closely aligned AND the tightest, most secure screw possible.![]()
That is flat out insane.
I don't precisely measure torque on interior trim screws but it is important not the screw em down too tight. I like to use a screwdriver for final tightening. Too loose and you get a rattle, too tight and you put more stress on the plastic parts eventually causing deformation and breaking.I did not know anyone measured the torque on trim screws. I wasn't talking about nuts and bolts.
I prefer not to risk it when tail lights come into play. Once its seated snug and flush, thats it, not any tighter. I only fasten plastic parts by feel.I agree. However, it is less than 45 degrees of a turn of the screw either way to make it straight. Is that the difference between a rattle or a broken taillight lens or trim piece? Loc Tite would work for machine screws.
