Lasthope05
- Aug 29, 2007
- 1,113
Many people make the assumption that if your not using a DA, Cyclo, or Rotary polisher there is no way you are going to be able to do any type of paint correction work. My eyes really opened up when a member on Meguiars Online posted an experiment and showed that a traditional orbital polisher(TOB) is not just a wax spreader but is capable of removing defects with the right products and techniques (A little testing/playing around! - Car Care Forums: Meguiar's Online) This really got me thinking, if a TOB is able to remove 3000 grit sanding scratches I'm sure other OTC machines and products marketed for paint correction should be able to do the same.
In our present economic situation it is not always possible for people to spend $200+ on a polisher and pads so working by hand is their only option. It is for these budget constrained people I have found a completely viable option. The Mothers PowerBall.
Mothers manufactures two different types of PowerBalls to be used on an electric drill. The original PowerBall(Mothers Original PowerBall Polishing Tool enables you to polish metal, plastic & painted surfaces using your electric drill! Mothers PowerBall is made ) and the PowerBall 4Paint (Mothers PowerBall 4 Paint, Mothers PowerBall 4Paint, Mothers Power Ball, Mothers paint polishing ball, polish paint, wax ball, mother's, mothers wax, ) In my testing, I use an original PowerBall mini which I purchased a few years back. While not recommended for use on paint, I found it worked so well that it surprised even me.
When using a the Mothers Powerball I find that it has some really nice qualities to it. If using the top flat portion of the ball it mimics the aggressive cutting action of a rotary, but if you also turn the drill 90 degrees and use the sides that mimics the same straight line motion one would use while hand polishing.
Seeing how the Mothers Powerball is in essence a mini rotary I decided to treat it as such. I taped off a section on my test hood and began wet sanding(1500grit) and polishing(M105 & M205.) I was surprised at what I saw and how much correction there was. After two hits of M105 via KBM the sanding scratches and tracers were all removed. All that was left was compound haze that M205 took care of.
Original paint condition
Wet Sand with 1500 grit paper
M105 via Mothers Powerball mini (first hit)
M105 via Mothers Powerball mini (second hit)
M205 via Mothers Powerball Mini
Final product
Products used
Final product
Products used
