Who's using polycharger
WEST SIDE
Member
Do you feel that it's worth adding to non poly charged products.I just used the H2o polycharger to some KSG and it got me thinking.
Four Star is polycharged, so is Ultima line. I did mixing in past with nice results its kinda cool.
Unless Menz comes out and says it's OK to use with their Powerlock, I'm not gonna experiment with adding unknown chemicals to someone else's product. It's just not a good practice.
I like the H2O PC. I like adding to QD's making them essentially a spray sealant. D also add to DP TG, DG 531 and other H2O based products. Difference with some is significant, both durability & slickness. fk425STANDS OUT NOTABLY, Only do 4 Oz until you test and then make more. No breakdown with PC H2O. It is half price on AG now.
Half price? I might have to snap some up shortly. Im the MAN
You know I'm a huge polycharger fan.
The only bigger fan than me that I know! Also the first to do a blind test of boosted DP TG V2.
Is it true that when mixed with a detail spray that there is no worry about shelf life?
I know when mixing sealants or waxes you have to discard after 48 hours.
Isn't Ultima's UPGP and Blackfire Sealant Polycharged?
I've been using the H2O additive on detail sprays for a couple of years now, in 32oz. spray bottles, the shelf life is fine. I had a couple of sprayers that clogged up and maybe I added too much, but the last time I Polycharged FK425 it tended to be a little streaky, probably more so than just the Fk425 itself.
I use the CH2 and love it. IMO it really makes an improvement in the durability of LSPs
I have used the CH2 two times and it definitely improved the durability.
It also changed the application characteristics. One mixed, the sealant was almost gelish and worked more like a wipe on / wipe off type product. You just seem to wipe it down but there is really no haze to remove. It did seem to add a very slight yellowish tint to the paint.
I talked to Sam (owns Premium Finish Care) and he had suggested backing off the dosage a tad to give it a bit more time to haze if I was not happy with the application.
